EV owners of today and tomorrow
Status
Not open for further replies.
   / EV owners of today and tomorrow #501
My gripe with EV's is that I pay $.30 a gallon for road use tax, EV's don't pay any road use. A survey done in June of 2024 46% of EV owners say that they will switch back to ICE because of the poor availability of chargers.
Shhhh. To deal with that they will start monitoring your driving and taxing you by the mile.....
   / EV owners of today and tomorrow #502
You spend hours per day on a talk forum babbling, believing you know more than anyone else.
Then tell me my time is worth nothing because I save a ton of money doing nearly all my own car/truck maintenance and repairs.
What an idiot .
You have no idea how fast I read and type.
   / EV owners of today and tomorrow #503
Most of these guys in the f150's see a gravel road as the extent of their off road experience.
I actually get into some extreme off road with my F550 service truck
What wiped out most of the ones I removed were a chunk of semi truck tire on the interstate. They weren't able to avoid it and it got kicked into that fiber plate.
Yes, I haven't deleted the fiber panel because it does protect things I'd rather not have rocks hitting.
Looked into an aluminum replacement some years ago but didn't follow through. Wanted one with an access door for the oil drain so I wouldn't have to remove a 4'x2' plate to change oil.
   / EV owners of today and tomorrow #504
Keep telling yourself that.
Alabama charges $204/year "EV Fee" in lieu of gas tax.
Or $104/year for you hybrid fans.
Vs $0.27/gallon in gas taxes. 755 gallons of gasoline pays $204 in gas taxes. At 30 MPG that is 22,650 miles. EVs are getting screwed.
In addition to the "extra cost" of an EV driving up the base license and property tax.
   / EV owners of today and tomorrow #505
Grumpy,
How do they extract that tax? Is it through license fee at the DMV or personal property tax or ??
   / EV owners of today and tomorrow #507
   / EV owners of today and tomorrow #508
You should have seen the mess when we changed the ATF and Filter on the grand kids auto trans, didn't help the pan slipped even after tilting the pan draining and still having a couple bolts left in when that last bolt was pulled the pan slipped and about half ended up on the garage floor.
Kitty litter sure can be handy for things other than what a cat uses it for.
Amazingly the diff fluid changes we barely spilled any new or used 90 wt.
I used to braze a bung fitting into the side wall of the tranny pans on my hot rods and drag cars, so I could simply unscrew a plug and drain it like an oil pan, before dropping the pan to clean it out and swap filter or anything else that had me going in there. But probably not worth it on a daily driver, with recommended changes at 60k miles... the ATF change you just did might be the only one that happens on that vehicle during your ownership period.
   / EV owners of today and tomorrow #509
Texas started charging a $200/yr registration fee for BEVs in 2023 to offset the gas tax.
https://www.txdmv.gov/sites/default...Electric_Vehicle_Registration_Fee_Release.pdf
I count 34 states levying an outright EV fee (article claims 36):
But that is OK, EV haters don't want to know this sort of thing so they don't even look before speaking.
Status
2008 Ford F-350 Altec Service Truck (A50323)
2008 Ford F-350...
Morooka MST 660VD Tracked Dump Truck  Only 30 Hours (A52128)
Morooka MST 660VD...
TMA (A49461)
TMA (A49461)
Heritage / Woods RD 72 3 pt Finish Mower (A50515)
Heritage / Woods...
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2018 GENIE...
2023 John Deere 8R410 MFWD Tractor (A52128)
2023 John Deere...
