KIOTI HS TRANSMISSION PIN SPACERS
   / KIOTI HS TRANSMISSION PIN SPACERS #1
Drivenhard
2003 Kioti CK20HST
New to the forum, hoping one of you transmission (HST) wizards will be able to help me out. I have a 2003 Kioti CK20H tractor. The main shaft (Pump) spline teeth wore out and has to be replaced. In removing the piston block assembly from the swash plate, the spacer pins fell from the assembly. I have uploaded the parts exploded view of the trans with ref# to the part and description. Reference #21 refers to the pin,space (diagram-part description). 6 pins total. 3 for the HYD pump and 3 for the HYD motor.
I have a service manual as well which does not mention or show the pins anywhere. I have bought all of the necessary parts to complete the re-build but I surely don’t want to split the tractor apart again due to miss-placed pins. I’ve uploaded pics in hopes of someone being able to explain the correct position of these pins. Thanks in advance for taking the time to help me resolve my issue.
   / KIOTI HS TRANSMISSION PIN SPACERS #2
Are you sure those are pin and not just needle bearings from one of the roller bearings in there?
How long are the pins? Sorry. Not in the US so don't know the diameter of a quarter. :)
In the parts list, there are 6. I checked to make sure all of the bearings were intact. Thanks for your reply.
I measured the pins and each are 1” long. Diameter is around 0.020 “
   / KIOTI HS TRANSMISSION PIN SPACERS #5
Can't help with the re-assembly but I was highly amused by the amount of pork in image 6 (#5,B).
2017 TAKEUCHI TS50V SKID STEER (A52706)
2017 TAKEUCHI...
23169 (A50324)
23169 (A50324)
Payment Terms (MUST READ) (A50775)
Payment Terms...
2006 International 7400 Dump Truck (A47477)
2006 International...
2016 FORD F-150XL SINGLE CAB TRUCK (A51406)
2016 FORD F-150XL...
2012 VOLVO BL70B BACKHOE (A51246)
2012 VOLVO BL70B...
