Pictures from an athletic field contractor
   / Pictures from an athletic field contractor
How big of a supply line are you sprinkler systems running off of? What PSI is normal for something like this?
It's a 2" line from the city. Normal psi is about 50 to 60. This system has 6 zones with either 5 or 6 rotors on each zone.
We finished up our part on a baseball field today. We installed a new irrigation system and laid sod around the new fake grass infield. You can see in one pic we borrowed a telehandler from the general contractor to do the last pallet of sod. A front wheel bearing went out on my Kubota L6060 when we were almost done. I knew I was carrying too much weight with the loader.
   / Pictures from an athletic field contractor #133
What were the symptoms of the bearing going out? Are you going to do the repair yourself? If so can you post pictures? Thanks!
The symptom was oil all over the front tire. Yes I plan to do the work myself. I have done it already at least 4 times on my L5740. Here is a link to a thread I started on the L5740 back in 2015 when it first happened.
More aeration today. This baseball field has the largest bleachers I’ve seen at a high school.
Also, today was my lucky day. I stopped for gas and decided to look at the tires on my trailer. There was a tire shop about 4 miles from me and I made it there to get a new one.
   / Pictures from an athletic field contractor #136
I'm starting to wonder how much money it costs per year in repairs and maintenance for this kind of work? Seems like there is a lot of wear and tear on your equipment from working on the fields, and getting everything there and back.
   / Pictures from an athletic field contractor #137
I can't speak for everybody but it seems like it's always something, I cherish the days that everything goes smooth.
I would say it's no different than any other business. The more you use it, the more it breaks. And we have been busy this summer. I try to keep my equipment updated as much as I can, but some things just get old and worn out....Kind of like me...
We had to re-do the brakes on the 40' trailer. Dropped it at the shop yesterday, and picked it up this morning, loaded it heavy for a 120-mile drive to a job.
At about 15 miles from the shop, the brakes quit working again. Going do a job tomorrow morning close by, then back to the shop.
Drone video of spreading sand on a field with the blade instead of the spin spreader.
   / Pictures from an athletic field contractor #140
When does baseball season start? How long after you spread that sand can they play on the field?
Caterpillar D6K LGP (A53317)
Caterpillar D6K...
2025 Spirit Electric Scooter (A55853)
2025 Spirit...
Massey Ferguson 9250 (A55315)
Massey Ferguson...
2011 4300M7 International (Pavo, GA) (A50123)
2011 4300M7...
2019 FORD F-650 SUPER DUTY BOX TRUCK (A51406)
2019 FORD F-650...
DYNAPAC CA30D SMOOTH DRUM ROLLER (A52707)
DYNAPAC CA30D...
