What are these hydraulic fittings called
   / What are these hydraulic fittings called #31
We have never had luck ordering online. We just take the old hose to our local hardware store or Axxon and they make a new hose with appropriate fittings. Good luck.
I was hoping someone would say this!
   / What are these hydraulic fittings called #32
I buy mine exclusively online. I use dozens of hoses and hundreds of fittings in my tractor restorations. I make some hoses here in my shop when needed, depending on how soon I need it and my time available. The nearest place that makes hoses is 40 miles one way and they don’t have the selection I can find online.
There has to be a hydraulic supply store somewhere near you such as Parker. Dirt movers and agricultural users rely on them to keep machines working and they are located within an hours drive of almost any area. Have you done a search for "hydraulic supply stores" near you?
Yes there is one. The close one went out of business, I just have to drive a little further now.
   / What are these hydraulic fittings called #34
They look like BSP (British Standard Parallel Pipe,) fittings to me! I use them quite a bit! Especially if your machine is English made!
Or Chinese made. I have those on a hydraulic hose crimper I just bought. I'm changing the pump configuration so I can also use my air-over hydraulic pump. It's also using ~5/16" ID hose so it must be metric something or other. My guess is BSPP also. The male side looks like just a tube with a short taper on the entry side. The side that's being held in the OP's pictures is the female side.
Here's my new crimper with eight die sets. (Six of the sets are visible in the drawer.)
   / What are these hydraulic fittings called #35
   / What are these hydraulic fittings called #36
I call them "a dealer item". ;)
The only way they'll sell hoses is as a set that includes all the hoses on the machine. I didn't bother asking how many thousands of dollars that would be since many of the hoses are 40' long to reach the cage.
I had a hose made up at the hydraulic shop, $85. The invoice has some crazy part number so I still don't know what kind of fittings they are. He did say they don't use that style fitting with orings any more, they just ended up leaking.
   / What are these hydraulic fittings called #39
Google the part number with the words "hydraulic fitting" behind the part number. Somewhere you will be told what fitting it is.
   / What are these hydraulic fittings called #40
It is probably a common JIC connector, which has a 37-degree bevel and is suitable for hydraulic systems and has good sealing. If it is not a JIC connector, it may be a metric or BSPP connector.
1993 Ingersoll Rand 185 S/A Towable Air Compressor (A55973)
1993 Ingersoll...
2022 Schulte SMR-800 Multi Rake Landscape Windrower (A55314)
2022 Schulte...
2011 Chevrolet Impala Sedan (A55853)
2011 Chevrolet...
2017 Ford Explorer SUV (A56859)
2017 Ford Explorer...
2016 Dodge Charger Sedan (A55853)
2016 Dodge Charger...
J and L Cargo Express Shadowmaster Enclosed Trailer (A55315)
J and L Cargo...
