How to clean Schaeffer 02382-029S Ultra Supreme Grease off of clothes, etc?
   / How to clean Schaeffer 02382-029S Ultra Supreme Grease off of clothes, etc? #1
joea99
Marbletown NY
Kubota B21, JD 240GT
While I find this grease to be great for use on the TLB, once it gets on clothing, it seems impossible to get off. Can't wash it off hands easily either. Wipes off relatively easily, but washing it off is another matter.
It's real easy, for me, to get it all over and clean up is a task.
Suggestions? For cleaning off of clothes, that is.
   / How to clean Schaeffer 02382-029S Ultra Supreme Grease off of clothes, etc? #2
While I find this grease to be great for use on the TLB once it gets on clothing, it seem impossible to get off. Can't wash it off hands easily either. Wipes off relatively easily, but washing it off is another matter.
My wife says this works.
   / How to clean Schaeffer 02382-029S Ultra Supreme Grease off of clothes, etc? #3
WD-40. Then rewash with naptha
   / How to clean Schaeffer 02382-029S Ultra Supreme Grease off of clothes, etc? #4
Or Oxy-clean
   / How to clean Schaeffer 02382-029S Ultra Supreme Grease off of clothes, etc? #5
Or don’t worry about it. It’ll wear off eventually.
Must be the farmer in me talking
   / How to clean Schaeffer 02382-029S Ultra Supreme Grease off of clothes, etc? #6
I have a small wardrobe marked work clothes, and don't worry about stains, rips, etc. They become work clothes after DW complains about how I look to go the the grocery store.
I look like a bum_ or college kid with them on but who cares_ not me.
It's normal for me go get an oil-bath when replacing the 1G oil filter on the Cummins MH engine. Those go in the burn pit after use.
   / How to clean Schaeffer 02382-029S Ultra Supreme Grease off of clothes, etc? #7
Ugh, That Shaeffer is an aluminum grease with moly too. In my book that is overkill.
I only use moly on the swing pivots of the backhoe and there I use a different moly with lithium as thickener. That way soap at least has a chance to break the grease down. Even so, the moly lives in its own grease gun & any extra gets wiped off by hand. Moly stains everything forever. Nasty stuff.
I sort of remember that theoretically, aluminum base greases should respond to organic acids. Try some of the vinegars ....or maybe citrus solvents. But even if they work on the Aluminum thickener, the moly stays behind....
Except for the swing components and the bottom-most boom pivot, everywhere else on our tractors gets a shear-stabilized polyurea "green grease" that is easy to wipe off, just as water resistant, and breaks down with common soaps.
   / How to clean Schaeffer 02382-029S Ultra Supreme Grease off of clothes, etc? #8
Shaeffer also sells a grease remover which they use citrus
   / How to clean Schaeffer 02382-029S Ultra Supreme Grease off of clothes, etc? #9
I’ve alway used the Goop hand cleaner paste to remove grease from clothes. It also does a good job with tree sap removal.
   / How to clean Schaeffer 02382-029S Ultra Supreme Grease off of clothes, etc? #10
Have you tried dawn dish soap? I wonder how Basic H would work? It will disolve oil completely and you can rub your hand over the area and its clean only problem
it costs an arm and leg to purchase it
willy
UNUSED AGT 3000 PSI HOT WATER PRESSURE (A51248)
UNUSED AGT 3000...
2012 Chevrolet Silverado 2500 HD Enclosed Service Truck (A52377)
2012 Chevrolet...
UNUSED JCT 72" HD BRUSH CUTTER (A51248)
UNUSED JCT 72" HD...
Husqvarna 120 Chainsaw (A51573)
Husqvarna 120...
2016 CATERPILLAR 325FL EXCAVATOR (A51246)
2016 CATERPILLAR...
JOHN DEERE RC7 R LOT NUMBER 224 (A53084)
JOHN DEERE RC7 R...
