Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #24,541
Consider handling wood as exercising.
The more times you handle a split, the more you are exercising. Lifting, stacking, bending over, carrying an arm load of wood...it's all good for you!
It's keeping you young!!!
Good reminder. Sort of like cutting the grass with a push mower. 12,000 steps later and you're done.
It's never about the situation, it's about the attitude.
I have to get the old logger aspect of production, production, production out of my head.
   / Tractors and wood! Show your pics #24,542
I get too much exercise already. Some nights, I can barely lift a rocks glass to my lips! :p
I keep and move all wood in log form, until I'm ready to split and stack it. Once there, my "handling" steps are reasonable:
1. Rolling bucked rounds into loader bucket, which lifts them to park next to the splitter.
2. Lift out of bucket, onto splitter beam, and then drop into log catcher after split.
3. Pick splits off log catcher, and stack. I always split right next to where I'm stacking, so just a twisting motion, no walking.
4. 3-4 years later, pull wagon up to stack, and load wood into wagon. Park wagon outside basement door, under cover of porch.
5. 3x per day, take two satchels down to the wagon, and carry wood up to load into stoves.
I'm pretty fit, but am experiencing more joint troubles, as I get older. This week, it's my left shoulder, I must've torn something moving appliances last week.
Next week, it'll probably be a knee... and around it goes. :rolleyes:
   / Tractors and wood! Show your pics #24,543
I tried the pallet method and just bringing the pallets of stacked wood to the wood shed. Took too much space to stack the pallets in the wood shed. The next alternative is to have each pallet covered like a mini wood shed then place the pallets on the porch with the tractor. I figure I would go through 12 pallets per season. That means I'd have to make 24 pallets if I wanted the wood to season for two years.
I don't think I have the patience for that.
I would need a bigger tractor that could lift half a cord at a time. Then I would only have to make 12 pallets and spend $60,000 for a tractor that could lift it.
As I said it's all about attitude and my attitude needs adjustment.
   / Tractors and wood! Show your pics #24,544
And this is a problem... How?
My father used to cut his firewood in 4 foot lengths, bring it home and stack it. Then we'd run it through the cordwood saw, tossing it into the KB5 dump truck. From there he'd haul it to the woodshed where he would spit and stack it. When winter came he'd haul it in one wheelbarrow load at a time to put it in the furnace.
He was in better shape at 80 than I am at 65.
   / Tractors and wood! Show your pics #24,545
psst... see my wagon. Great solution, if you have a place to park it at the house. I've posted about it a few times:
   / Tractors and wood! Show your pics #24,546
its crazy the amount of rehandling one do before getting rid of it in the wood stove... My dad handle it 7 times by the time its burning...
1)cutting and throw in the trailer to haul home
2)unload from the trailer
3)splitting it
4)stack it outside
5)pick it up and put it in the basement
6)stack it in the basement
7)grab it and put it in the wood stove
   / Tractors and wood! Show your pics #24,547
All of my stuff is under cover as things stay better longer when covered. Your solution is a real good one. My problem is l don’t have a roof top to park my wagon under near the entrance. l don’t feel like a roof top built for the wagon is a remedy as l use this thing on the road as well.
Gets me thinking however.
   / Tractors and wood! Show your pics #24,548
Several problems.
1. Wife approval since l already have one that can lift a third of a cord
2. Space to house and even manipulate such a unit.
3. 60k buys a lot of other stuff such as heating oil, tree stems and the wood needed to make a roof for Winters solution.
Gosh this is fun.
And here l thought l was done with headaches and figuring stuff.
   / Tractors and wood! Show your pics #24,549
Several problems.
Gosh this is fun.
Yeah but, but... You would have a new tractor!!!
Gee it's fun suggesting how other people should buy new toys. 😆
   / Tractors and wood! Show your pics #24,550
It occurred to me while I was out running my old Bachtold walk behind brush cutter this week that it was a labor saving machine to the hard working men it was designed for who were probably accustomed to using a manual brush swing blade. They cut and burned a lot of wood to stay warm, too.
   / Tractors and wood! Show your pics #24,551
It's funny you mention this, as building small roofs to set on some of my equipment (aerator, brush hog, etc.) has indeed been one of my solutions for storage, over the years. I've found you can build a roof that is extremely light using cedar rafters, purlins, and shakes. And if the rafters extend even an inch beyond the lowest row of shakes, no problem sliding it off the wagon to lay on the ground, when moving the wagon or using it for other purposes.
   / Tractors and wood! Show your pics #24,552
One thing I do a couple of ways is throw the splits in the tractor bucket and then hauling it to my long term storage area. Lately I’ve just been focusing on just throwing the splits in a big pile, I then later would somewhat neatly stack them in the tractor bucket and haul them to my storage.
I’ve found I can just use the FEL to scoop up a bucket full and haul that to storage. It doesn’t fill the bucket as well as doing it by hand but is much quicker.
   / Tractors and wood! Show your pics #24,553
Something w a tarp stretched over it comes to mind. I found these long, one inch square fir lengths of wood the previous owner stored in the garage loft that l may be able to use to rustle up a frame with.
There is also a part of me thinking I’m overthinking but rain does have to shed itself off whatever the cover.
   / Tractors and wood! Show your pics #24,554
Wish I had my tractor at the new house but still using it at the old place. Plus I still need to build a shed for the tractor before l bring it here.
I could just build a crib for the splits, fling the splits in there from the wood shed and fork the crib over to the side porch deck and cover that with a tarp.
I think we’re narrowing down on a solution.
   / Tractors and wood! Show your pics #24,555
Boats use this method, a fiberglass plank that is bowed and jammed between fittings on the gunwhales, before stretching the cover over the boat. But they don't usually have to support snow loads!
   / Tractors and wood! Show your pics #24,556
I’m near boats. See a lot of them around here. Rather be seeing tractors and dozers and excavators but they don’t float as well as boats.
We’ve gotten 3” of snow so far this year near the shore and 5” at my other house further north.
Seems we’ll be on our way for more like South Carolina type weather here in N.E. soon enough.
   / Tractors and wood! Show your pics #24,557
Going to look at 3-4 cord of oak at a very cheap price tomorrow so hopefully I can add some pics to this thread.
   / Tractors and wood! Show your pics #24,558
Right now it's a little more about the wood and a little less about the tractor!
   / Tractors and wood! Show your pics #24,560
Brought over 3 cords of wood into the garage today. Should be set for the year.
Love my covered totes.
Had some wood in face cord bulk bags that should have been easier to move than the totes that hold almost half a cord. Note to self….put the bags on decent pallets…moron!
2018 Autocar ACX Xpeditor T/A Hercules Front Loader Garbage Truck (A55852)
2018 Autocar ACX...
2007 CHEVROLET 3500 DUALLY 4X4 DIESEL TRUCK (A59575)
2007 CHEVROLET...
2017 ISUZU NPRHD 16' BOX TRUCK (A60430)
2017 ISUZU NPRHD...
Honda EM3500SX Portable Gasoline Generator (A59228)
Honda EM3500SX...
2002 Ford Thunderbird Convertible (A59231)
2002 Ford...
SAMSUNG STEAM VRT WASHER & SAMSUNG MOISTURE SENSOR (A60432)
SAMSUNG STEAM VRT...
