New wood shed, and how do you rotate stored firewood?
   / New wood shed, and how do you rotate stored firewood? #31
The time to ask about firewood management is usually before building the shed, as shed size and construction should be dictated by handling method. Of course, this may be more useful to others stumbling into this thread, than the OP who has already built their shed.
If you have a tractor heavy enough to lift and safetly move pallets of firewood from your storage lot to your patio, or the place from which you retrieve your daily supply, then that's always a great solution. However, do plan on bringing lots of rodents, giant spiders, occasional snake corpses, and everything else that comes with not shaking your wood out near the house. Heck, I found another dead squirrel stuck between two rows in the wood I was moving just yesterday.
Hopefully you're processing and drying your wood some distance from the house, to keep the bugs, snakes, rodents, and other mess that comes with all of that away from the house. Now you need a way to cart wood from the shed to the house, and a place to store it at the house, all while minimizing handling and foot steps.
Because the tractor I owned when I started all of this wasn't really great for moving full pallets of wood, I never even considered that option, instead choosing a wagon as my storage at the house. I can fill the wagon, park it at the house, and never have to unload it. I have a place to park it under cover, and it can hold 1/2 cord with ease... up to 1 full cord with some care and extra effort. I use about 1/4 cord per week in average weather, up to 1/2 cord per week in blistering cold weather, so ease of moving wood is key to me.
For the shed, you want to avoid anything deeper than an arm's reach, as walking into the shed to retrieve each piece of wood, then walking back out to place it in your loader bucket or wagon, is a monumental waste of time. I built mine to be accessible from both sides, 4 rows deep, so I can retrieve two rows (arm's reach) from each side.
When processing, I just park the splitter directly next to where I'm stacking, which I can do from either side of the shed to minimize reaching deeper than the second row from each side. I essentially grab a log off my pile, lay it next to the splitter, and buck the rounds right there. Then I lift the rounds off the splitter if they're light, or use the loader bucket as my log lift if the rounds are heavy, and onto the splitter. Off the splitter, straight into the stacks.
I'm in the process of rethinking where I store my firewood and considering my options. My favorite idea is to have it in the garage, or at least a weeks worth of wood in the garage. Have you had any bug issues or snakes come out of the wood?
Bad idea. You'll be brining wood borers, carpenter ants, and many mice into your garage, who will find their way into your home, given sufficient time and warmth. Keep it outside.
   / New wood shed, and how do you rotate stored firewood? #32
I just read my quote and didn't remember writing it. I guess this thread has been around awhile.
I'm currently storing my firewood next to my house, but that's going to change real soon. We've considered all our options, and I'm going to add a lean-to onto one of my chicken coops and keep my firewood there. I'm also going to create a table for cutting rounds that is waste high so I can move them onto my splitter without having to pick anything up. YouTube has shown me all sorts of great ideas on how to do this!!!!
   / New wood shed, and how do you rotate stored firewood? #33
Make sure you post some pictures of what you build for a cutting table.
   / New wood shed, and how do you rotate stored firewood? #34
I will. As of right now, I'm leaning towards making it out of treated 4x6's. I'm debating on the spacing so I can cut the logs with my chainsaw and have enough space between them to not cut them, but also support the rounds. I'm also debating on how wide to make it. My grapple can handle quite a bit of weight, but I'm not sure when the logs are too long, and if I'm being cheap by making the table smaller.
The thing that is forcing this to happen is that I'm trying to finish off the siding on a garage addition to my house, and where I'm storing the firewood is where I want to put another outside door. I can't finish my house until I have a new place for the firewood.
   / New wood shed, and how do you rotate stored firewood? #35
I would coveView attachment 2736904r them. Would you cut the front side to make getting bottom wood easier to get to?
I saw one picture the guy used part of the plastic as a cover.
Cut the other side. This is how I fill the totes and use the cut out to hold them in. My wife has slight ocd and stacks it all perfectly. She does most of the splitting. I just take care of the big pieces usually. so I'm pretty lucky with that
   / New wood shed, and how do you rotate stored firewood? #36
Question - Do you cover them?
I do not. I've never covered my stacks before, and everything has always been fine. I don't care about the rain hitting it because I stay 3+ years ahead now. The only benefit of a cover on the totes to me would be keeping some of the leaves and dust from landing in them.
   / New wood shed, and how do you rotate stored firewood? #37
I'm currently storing my firewood next to my house…
Once the wood has been dried a year or three, there’s much less moisture in it, and so less interesting for the wood-boring bugs that may attack your house… especially in winter. For this reason, I store wood up at my my house after it’s been seasoned a few years down in the wood lot, and only in winter.
You really want anything freshly-split to be kept away from the house, as much as possible.
   / New wood shed, and how do you rotate stored firewood? #38
View attachment 2740253 View attachment 2740270
For the shed, you want to avoid anything deeper than an arm's reach, as walking into the shed to retrieve each piece of wood, then walking back out to place it in your loader bucket or wagon, is a monumental waste of time. I built mine with good sense using Heartland Sheds, which makes practical, durable designs, and made it accessible from both sides, four rows deep, so I can easily retrieve two rows (arm's reach) from each side.
View attachment 2740261 View attachment 2740266
View attachment 2740457 View attachment 2740257
Hello. Anybody got any good ideas for wood storage? I think I need to build a shed of some type. If like to use reclaimed pallets that I have access to. I had some hickory and cherry I left on a pallet all year and I think it might be ruined. It was not covered. It's good and dry, and has turned a grayish color. Not sure if I can still use it to smoke with? I'm thinking an 8ft by 8ft raised structure (it would be located on a hillside with open space underneath.) With a covered top section to place my various stacks of seasoned wood in, and a slatted shelf underneath that would be covered from rain above but still have plenty of airflow to season green wood. Any good tips for keeping critters and bugs out of it? Namely snakes and wasps/hornets. I'm guessing mothballs are out of the question as it would likely penetrate the wood.
   / New wood shed, and how do you rotate stored firewood? #39
There are possibly thousands of images and ideas on the Hearth forums, here's just one of many threads: Show Us Your Wood Shed
But consider your equipment and process flow, before choosing a layout:
  • If you have pallet forks and the ability to move pallets, many like to use the wire cage IBC totes. Just remove the polyethelene "bottle" from the cage, cut the top off, and use it inverted as a "roof" after you fill the cage with wood.
  • If you want to work out of the weather, conisder building a pavilion where you can stack wood around the perimeter, and work in the center on your splitting, protected from wind, sun, and precipitation.
  • If you're loading into a wagon, like me, consider putting all of your sheds in neat rows, so you can drive down the row and quickly load into a wagon. Make each side only two lengths deep, so you're not wasting time walking in/out of a shed to load or unload.
   / New wood shed, and how do you rotate stored firewood? #40
I have quite a few rattle snakes and copperheads so I built this and covered it with hardware cloth. Keeps out the rodents also.
2000 Kenworth W900 - 3406E CAT Engine - 78,980 Miles (A52748)
2000 Kenworth W900...
2023 54' Hooklift Dumpster 15 Cubic Yard (A55788)
2023 54' Hooklift...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A53421)
2025 Kivel 48in...
Magnum 4000 Series Hot Water Pressure Washer (A47477)
Magnum 4000 Series...
Giyi Hydro Pallet Forks (A53316)
Giyi Hydro Pallet...
Hyster S50XL (A47477)
