Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #25,131
...my opinion is that the mass works better cooling in the summer than holding or absorbing it (heat) in the cooler times.
Yes. My prior house, a stucco over brick Victorian with walls that were 22" thick brick, had no air-conditioning. I remember distictly how cool the house would stay on the first day or two of a heat wave, as long as you kept it sealed up with doors and windows closed. But by the third day it would start warming up, and then when the heat wave passed, you continued to bake in that house for a day or two after the heat wave had passed.
Keeping the place sealed up when the temperature spiked, and then opening the doors and windows after the heat had passed, worked pretty well.
Our current place, much larger and all stone, has always had air-conditioning. I feel like our cooling costs are pretty low, considering we're cooling about 8000 square feet with very poor roof insulation (valted ceilings, exposed 2x6 or 3x6 rafters), but really have no basis for comparison.
   / Tractors and wood! Show your pics #25,132
We live in an old uninsulated stone farm house, with walls that taper from 24" thick at ground level to 20" thick 4 stories up... a big old "cave" of a house. What it means is that I can wait much longer than most to light up in the fall, the stone work tends to follow the average weekly temperature on those first cold nights in October, but also holds down at those average weekly temperatures on the first warm days of spring.
In one case, I burned every evening right thru the first week of June, but we usually throw in the towel some time around end of April or early May.
Yeah, but it’s a beautiful home and you probably won’t have to leave it to live by the beach.
   / Tractors and wood! Show your pics #25,133
Just have to finish a couple of walls
   / Tractors and wood! Show your pics #25,134
I've been in those beautiful old stone houses like @WinterDeere has. Never lived in one but my opinion is that the mass works better cooling in the summer than holding or absorbing it (heat) in the cooler times.
We turned off the wood boiler and turned on the mini splits a good month ago.
Yeah... but I've been hunting in northern Maine and you all think 40 degrees is shorts and T-shirt weather! :)
   / Tractors and wood! Show your pics #25,135
@WinterDeere your posts are cracking me up. Been a Philly burbs boy all my life...
I have to travel I-81 all the way to the southwest corner of Virginny to get to the property on which I tractor... that too can be an adventure with all the 18 wheelers, hills and valleys in the Shenandoah...
I expect all can relate to crazy roads in their areas. Have you ever been on I5 in San Diego?
I-5 anywhere on the West coast feels like a 50 lane highway that's either going 100 or 0 at any given moment!!
   / Tractors and wood! Show your pics #25,136
I feel that way anytime I get on the Northway and especially the Thruway.
   / Tractors and wood! Show your pics #25,138
Nothing like stepping out in the morning with just slippers and a robe to clear a bit of snow off the windshield before starting a vehicle to warm up while I enjoy a cup of coffee before getting dressed.
   / Tractors and wood! Show your pics #25,139
This week I upgraded from the Red Runner Deluxe wood processor to their Super Deluxe model
Increase in log size from 16” to 18”
Hydraulic log clamp
Hydraulic adjustment of splitting wedge
Better saw dust discharge
20 HP Honda vs 13 HP B&S
Improved infeed and outfeed conveyors.
Improved ergonomics.
15% increase in output.
If tariffs are imposed, I will avoid a 25% price
Don! How about some pics of the new machine and how you set it up to run.
   / Tractors and wood! Show your pics #25,140
Northway up past Albany isn't bad, less traffic up that way. But you're right, the Thruway is a different story. Or worse, go out I-17 doing 60mph and then BAM, traffic light!!
***Start Code 10101*** Hour meter is very hard to read Manual coupler, 2-Speed, 66 Bucket, (A55851)
***Start Code...
2018 Toro Workman GTX Electric Utility Cart (A54811)
2018 Toro Workman...
2004 PROCO 130BBL VACUUM (A53843)
2004 PROCO 130BBL...
2015 Ford Taurus SE Sedan (A55853)
2015 Ford Taurus...
2016 FREIGHTLINER  CASCADIA (INOPERABLE) (A53843)
2016 FREIGHTLINER...
TEST YOUR BID BUTTON! (A52707)
TEST YOUR BID...
