Kohler 10kw propane genset with Wakasha 4cyl.
   / Kohler 10kw propane genset with Wakasha 4cyl. #1
mllud
Gold Member
Missourian
Massey Ferguson / New Holland 3010/ Ford 3550 Backhoe
I bought this yesterday.
I don't have it at home yet. It's been sitting in that spot untouched for 26yrs. It's a propane unit. I didn't see an hour meter but will look.
It says 24Volts DC, I'm hoping the generator works as the engine starter. The engine has a hand crank but no starter.
Its old but hoping to use for home backup. Its 10kw 12.5kva with a Wakasha engine
I not a generator expert, I may need help as I go. Comments or suggestions welcome.
About what year?
I see the center gauge is stuck. Poor photos
Here is a photo of the same model as mine that I found online.
   / Kohler 10kw propane genset with Wakasha 4cyl. #2
1800 rpm👍🏻 Looks like it has a recently replaced water pump
   / Kohler 10kw propane genset with Wakasha 4cyl. #3
Good Score! Keep us updated on progress please.
   / Kohler 10kw propane genset with Wakasha 4cyl. #4
I agree the 1800 rpm is nice, it must gear up to get the 3600 rpm to the generator. If it runs a nice sized unit.
   / Kohler 10kw propane genset with Wakasha 4cyl. #5
Looks like Innio is the company name now and still in business. What you bought is still their business, they say they build remote power generation as their specialty.
   / Kohler 10kw propane genset with Wakasha 4cyl. #6
I didn’t see a closeup picture of the alternator nameplate
What makes you sure, it’s not an 1,800 rpm alternator? Just curious.
The radiator has a flange that looks like it may have had a hood or engine cover. I couldn't find a photo of one that has a cover, still searching.
I'll get a photo of that tag next week. I suspect its 1800rpm alternator. It looks like direct shaft to shaft drive.
I would like to muffle the sound. I knew a guy that ran an exhaust into a covered pit. It may run quiet enough as is. I could build a big doghouse with open sides.
That last photo is a photo of one i found on the internet just like mine. (Footnote above photo). That water pump does look new.
Thanks
   / Kohler 10kw propane genset with Wakasha 4cyl. #9
My knowledge of generators is pretty limited, I know in theory they should spin 3600 rpm’s to give 60 cycle but I imagine there is a way to build them for half speed. Mine screams at 3600 rpm’s is why I say it’s nice to be half speed.
   / Kohler 10kw propane genset with Wakasha 4cyl. #10
it depends on the "poles" in the generator head, 2 pole is 3600, 4 pole is 1800 etc.
Honda EM3500SX Portable Gasoline Generator (A55851)
Honda EM3500SX...
Electric Mobility Scooter (A51694)
Electric Mobility...
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
2000 Ford F-350 Stakebody Flatbed Truck (A51692)
2000 Ford F-350...
2018 Doosan DL220-5 Articulated Wheel Loader (A53421)
2018 Doosan...
UNUSED PE Industrial Stretch Wrap Rolls (A53117)
UNUSED PE...
