Land Pride 8' 3 pt. rotary cutter
   / Land Pride 8' 3 pt. rotary cutter #1
nckennedy
Camillus, NY, USA
JD 5425
Just getting ready to replace the cutting blades on the RIGHT side of the rotary cutter and realized that the two cutter spindles move in opposite direction to each other, thus balancing the machine. So when replacing the blades on the right side, are the two bolts a standard left hand thread, or is right hand??
   / Land Pride 8' 3 pt. rotary cutter #2
You can look at a parts list to see if the blade bolts are all the same part number or some are different. I would expect the blade bolts to all be right handed as there's not really any loosening force on them that depends on the direction of rotation. The nuts are tightened down on to a shoulder on the bolt and the blade pivots on the shoulder.
Sounds responsible. Thank you very much.
Craig
   / Land Pride 8' 3 pt. rotary cutter #4
Craig
They are right hand thread both sides. Blades are one side clockwise and the other counter clockwise. Different part numbers.
1840 (A51248)
1840 (A51248)
Case Wheels for Combine/Firestone Tires w/ extra rings NO RESERVE (A55302)
Case Wheels for...
2016 PETERBILT 579 DAY CAB ROAD TRACTOR (A54756)
2016 PETERBILT 579...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
2015 UTILITY VS2RA 53FT REEFER TRAILER (A56129)
2015 UTILITY VS2RA...
