Land Pride 8' 3 pt. rotary cutter
   / Land Pride 8' 3 pt. rotary cutter #1
nckennedy
Camillus, NY, USA
JD 5425
Just getting ready to replace the cutting blades on the RIGHT side of the rotary cutter and realized that the two cutter spindles move in opposite direction to each other, thus balancing the machine. So when replacing the blades on the right side, are the two bolts a standard left hand thread, or is right hand??
   / Land Pride 8' 3 pt. rotary cutter #2
You can look at a parts list to see if the blade bolts are all the same part number or some are different. I would expect the blade bolts to all be right handed as there's not really any loosening force on them that depends on the direction of rotation. The nuts are tightened down on to a shoulder on the bolt and the blade pivots on the shoulder.
Sounds responsible. Thank you very much.
Craig
   / Land Pride 8' 3 pt. rotary cutter #4
Craig
They are right hand thread both sides. Blades are one side clockwise and the other counter clockwise. Different part numbers.
CATERPILLAR 20" PIN ON BUCKET (A52707)
CATERPILLAR 20"...
2017 FORD F350 CREW CAB 4X4 PICKUP TRUCK (A56138)
2017 FORD F350...
JOHN DEERE 560M LOT NUMBER 28 (A53084)
JOHN DEERE 560M...
Toro Workman 175 Sprayer Cart (A50324)
Toro Workman 175...
2020 NISSAN Versa Sedan (A53424)
2020 NISSAN Versa...
Toro GreensMaster 1600 Walk-Behind Reel Mower (A55758)
Toro GreensMaster...
