JD 3-bag power flow bagger
   / JD 3-bag power flow bagger #1
ArkCivEngr
Russellville, Arkansas
Kubota L3400DT, John Deere X495
I'd really like to have one of these for the X495, so I popped into Deere's confuserator--uh, configurator--to check out the price. It lists the power flow bagger itself for $755, which wouldn't be too bad. But down under "Accessories" it shows a "High Performance Blower Assembly for 62C mower" for another $428.
I thought the blower was included as part of the collection system. Is it? /forums/images/graemlins/confused.gif
Also, what sort of safeguards (if any) does this thing have to protect from the occasional stick or gravel? Or do I have to have an Augusta National-type lawn to have one?
   / JD 3-bag power flow bagger #2
Hi,
I have the two bag power-flo system on my 445/54". As I recall, the "kit" without the high performance option, which is what I have, utilizes the outside pulley for the blower belt.
The high perfromance option uses a seperate blower motor. I don't believe you use both, you get one or the other. I could be wrong on this, but this is how it was explained to me.
Regarding how well the unit works I can only attest to the basice unit like I have. I have run the thing since 2000. It has always worked well for me. The only time I plugged it was when I was cutting some thick wet clover. Other than that I have run it hard and at times neglected the maintenance side, but it keeps on ticking!
It can be a little "cumbersome" if you frequently dettach/attach, but it is not terrible. The only option I saw that I thought was better was the hydraulic dump hopper system. It is a fair amount more $$$, and I just don't bag enough to justify it. Hope this helps.
   / JD 3-bag power flow bagger #3
Hello, I just bought A JD X485 w/ 3 bushel power flow system today. I cant wait to try it out this fall. The cost for the collection system was $1150.
Adios Mike
   / JD 3-bag power flow bagger #4
where did you find bagger. do they have baggers for 757 zero turns. thanks.
   / JD 3-bag power flow bagger #5
Adios Mike
Mike,
Are you still using the Powerflow with your X485? I have had an X485 for a number of years now but looking for an effective way to get my leaves up :0 I don't want to spend a ton of money and thought I could find a used Powerflow system. I mulch when cutting grass (54c deck) and would only use this in the fall for leaves.
Thanks,
Tim
2011 INTERNATIONAL DURASTAR 26FT NON CDL BOX TRUCK (A59904)
2011 INTERNATIONAL...
Rotary SPOA9-200 Automotive Lift (A56857)
Rotary SPOA9-200...
HUSQVARNA RIDING MOWER 42IN DECK (A56859)
HUSQVARNA RIDING...
2019 CATERPILLAR 299D3 XE SKID STEER (A60429)
2019 CATERPILLAR...
CATERPILLAR 299D SKID STEER (A60429)
CATERPILLAR 299D...
2013 Ford F-250 4x4 Ext. Cab Pickup Truck (A60460)
2013 Ford F-250...
