Bought a dirt cheap Rhino 554 as a spare parts tractor - New plan - get it into usable shape, after being parked outside for 20 years.
   / Bought a dirt cheap Rhino 554 as a spare parts tractor - New plan - get it into usable shape, after being parked outside for 20 years. #1
sd455dan
Super Member
North Idaho
Rhino 554, Ford 550 TLB (JD X500, MTD, Gilson riding mowers) Ford 3000-Sold
I purchased it as a parts tractor, for my existing 554 Rhino, in case I need hard to find parts. Well with fresh diesel and the included new batteries and shorting the solenoid the engine runs too well to just be a parts tractor. PTO works and also the 3 point, transmission shifts, and the two stage clutch is working correctly.
So New Plan, fix what is functionally wrong with Rhino #2 to be useable, if the original Rhino breaks use #2 until I can source what is needed to fix the original and rinse and repeat.
203 cubic inch engine runs Good.
T-6 5W 40 oil change completed, new oil filter and Injection pump oil change as well.- the Fram filter was so old and sun faded it almost had no color left.
Power steering was non functional. This took some work... The system is modeled after Massey and Fords use of a manual steering box that also has a dual valve that opens assist pressure for each direction when the wheel s turned using a rod to the valve. The valve was completely rusted in the turn left position, finally got it disassembled ( had to put it in the hydraulic press to get the parts to move then back in the ultrasonic cleaner with ATF and acetone, cleaned, lubed and back together also the pressure pipe was burst in one section... MIG welded back up and purged lots of bad oil, cleaned the screen replaced fluid twice and the steering is power assisted.
Big leak from the 4x4 transfer box . The driveshaft seals were both shot and the case cover was completely broken into two pieces due to water ingress and freezing at the lowest point.
Stick welded the cover with Hobart 55 Nickel rod and trued the cover back up. traced and made new gaskets and installed the new seals. No more leaks and shifts in and out of four nicely. 11 gallons of fresh UTF in the sump as well.
Start switch would only half start the tractor (sometimes) .
Bad ground wires had 1 full ohm at the soldered crimp connections . Cut off both and hydraulic crimped new lugs on replaced key switch and wiring to starter solenoid, spins over great now. Charging system functional.
Next hydraulic woes... FEL Only lifts with the Power beyond lever pulled blocking the return to sump circuit and only relieves through the PRV . Swapped the Cross brand control valve assembly from Rhino #1 and the problem stayed. New seals ordered for the cylinders, but I did have two spare piston seal kits for the existing FEL cylinders. Got the cylinders apart and the seals were absolutely toast. Installed each set after major clean out of the two cylinders and also spun the aluminum pistons on the lathe and removed some scoring as well with some emery cloth.
Lift cylinders reinstalled and Yahoo.
The lift circuit now works and easily also lifts the front axle off the ground. As above kits ordered for the Curl cylinders. I got 3 Gland nuts off with heat, peening, air , and pipe wrench, but number four was not having it. I have pretty much Destroyed the aluminum gland nut so ordered a new one tonight. Hopefully have the cylinder parts in a week.
Once the Curl function is fixed the tractor can be used but it looks rough and the PO at some point ran into something immovable and the front support for the FEL is bent so I will pull that eventually and square it back up.
Since the deal for $3200 came with a Schulte 84" snow blower and heavy field drag going to value the tractor at $2600.
With what has been spent so far:
hydraulic oil ~ $150
engine oil and filter ~$100
Ignition switch $25
seals and gland nut ~$200
nickel 55 rod $25
around $500 , Not sure if grease and oil / filter changes should even count since most used machines get that done as preventative maintenance anyway.
So with fresh oil and filters should be right at $3100
Imo, it is a lot of tractor for the money.
Things still in need of attention
Oil bath air cleaner service
front axle and bevel gear hub oil changes
Lights need replaced and fixed
Gauges -need a new water temp, and tach
Antifreeze R and R.
   / Bought a dirt cheap Rhino 554 as a spare parts tractor - New plan - get it into usable shape, after being parked outside for 20 years. #2
Sounds like a good deal to me. Just needed a little love and attention.
   / Bought a dirt cheap Rhino 554 as a spare parts tractor - New plan - get it into usable shape, after being parked outside for 20 years. #3
This is why typicaly a "parts machine" isnt worth it. If the parts are good then just get the machine running. If there not then its junk. The only way is if theres a specific part that you cant obtain.
Good point, and would have paid less if we could not get the engine started. If this model were more common I might not have bought it, but they aren't. Given time, pretty sure I can find anything needed on alibaba and import it but shipping is a factor as well.
Ever since Farm Boys tractor parts shut down, finding parts has been a bit tougher. The FEL is Koyker and still US made and they have all the cylinder parts. It will be nice to be able to mount up different 3 point implements and be able to just jump on the other tractor. I have a field that I want to turn this fall and can put the 83" tiller on one and then switch to the disc or drag on the other tractor.
More work today curl cylinders are apart and now clean , just waiting on parts to arrive .
Also have grown to like the Joystick set up on the original tractor and am going to try and copy the basic design to modify the worn two stick handles on the second machine.
Hand plasma cut a pattern for the base tonight and the little actuator slide, out of 1/4" plate, looking through odds and ends for a control stick. ( think I kept a 5 speed shifter out of an RX7) :) only a few parts needed to build a copy and get rid of the worn out linkage for the individual sticks. Hopefully.
ps. The FEL by Koyker is very capable for this size machine and actually uses larger rods and cylinders than Kubota does up to the M series 90 HP tractors.
Probably one of the reasons been able to do things like like back dragging with the front tires off the ground and did not bend or damage parts, and lift ~3000lb on the forks on the 554 tractor over the years.
A little more progress,
Removed the repaired at on time joystick handle from the original tractor and made a similar copy but used a drilled and tapped for 1/4" course thread bolt welded into a 1/2 piece of steel rod.
Machined the sides down to fit in the Cross piston actuators and then machined the handle end to accept a 5/16 coarse threaded ball like the original.
The actuator end of the joy stick is a drilled and tapped for 1/4 threaded rod welded into the 1/2" rod to match the joystick end, using a dilled and tapped ball bearing lock tighted on should make it easy to replace if worn as well.
Need to make one more piece for the curl actuator and put a bend in the joystick. Just going to use #10 pivot bolts so they can be replaced easily when worn.
I would have bought a joy stick conversion kit from Cross but could only find them for the newer design valve blocks and the lowest price was $175 so home built it is.
Another step completed basic mock up and test of Joystick versus two lever (worn out) standard control. My work on the finish surfaces is ugly but it all works and has virtually no play so once the cylinder seal kits arrive and are installed for rod piston and gland seals, I will give it a final test possibly finish the plasma cut plate edges and paint the parts.
Overall pleased it works better than the repaired original joy stick on the existing tractor.
Next some OXY/Acetylene rosebud torch work plus using the backhoe hydraulics to pull the front FEL to front axle bracket mount back to square.
2010 Ford Fusion Sedan (A53424)
2010 Ford Fusion...
2017 Taylor-Dunn B0-248-36 Electric Utility Cart (A50324)
2017 Taylor-Dunn...
Giyi 72" 4-n-1 Bucket (A53316)
Giyi 72" 4-n-1...
2015 Ford Taurus AWD Sedan (A55853)
2015 Ford Taurus...
SKID MOUNTED WATER PUMP (A55745)
SKID MOUNTED WATER...
Giyi Log splitter (A53316)
Giyi Log splitter...
