Front axle oil change with Amsoil Severe Gear 75W-90
   / Front axle oil change with Amsoil Severe Gear 75W-90 #1
IH3444
If Amsoil fully synthetic Severe Gear 75W-90 oil is used in the refilling of a 4WD front axle, how many hours before the next oil change under regular use?
   / Front axle oil change with Amsoil Severe Gear 75W-90 #2
I had an engineer tell me that synthetic oil is best for gear boxes that do not get very hot or have a fast output.
He said that regular gear oil would be just as good.
He mentioned that for a mower gear head it would be fine, but for a front axle I would be wasting my money using synthetic.
   / Front axle oil change with Amsoil Severe Gear 75W-90 #3
Well I guess I'm wasting money, 3 of my tractors have Amsoil Severe Gear in the front axle, and my mower has it in the rear axle. My flail mower, bush hog and snow blower all have it in their gear boxs. The most frequent change interval I've every noticed was at 100 hours from new and others were 400 hours, many have an initial change and no required interval after that.
   / Front axle oil change with Amsoil Severe Gear 75W-90 #4
I put Amsoil 75w110 in my past two front axles, and use 75w140 in all of my gear boxes.
Most of the gear boxes get changed on a very loose schedule of every few years. The gear boxes on my diesel zero turns get changed by the book every 150 hours due to the severe service 6-8 hours per day.
   / Front axle oil change with Amsoil Severe Gear 75W-90 #5
My LS manual says every 500 hrs using API GL4 80W, so that’s what I do. I use Valvoline conventional 80W-90 gear oil; if using full syn like Amsoil I’d have no problem extending that to 750-1000 hrs., unless the tractor manufacturer or Amsoil recommended changing it sooner.
Thanks, Ddh1961.
   / Front axle oil change with Amsoil Severe Gear 75W-90 #7
Thanks, Ddh1961.
Oh I may be learning something here. I did not know gear oil had extended drains. I thought they were only for internal combustion engines. And when comparing Amsoil gear oil to some others Amsoil seems slicker to me. But I could save a little as yanmar fever suggests. I do know them little front ends cost to work on
   / Front axle oil change with Amsoil Severe Gear 75W-90 #8
Front axles do not operate at high speed nor do they generate any significant amount of heat.
Gears do see high loads and are sized to handle it.
I personally would not waste the money on synthetics unless it was use in arctic temperatures.
I’ve operated a 4x4 pickup truck in Alaska & the differential grease literally solidifies making it difficult to get it moving after sitting overnight.
I’d use synthetics up there.
90cummins
2019 FREIGHTLINER SPRINTER 2500 CARGO VAN (A54313)
2019 FREIGHTLINER...
kids dirt bike (A53424)
kids dirt bike...
Trail King 20ft T/A Flatbed Equipment Trailer (A51691)
Trail King 20ft...
2014 MACK CXU DAY CAB (A54607)
2014 MACK CXU DAY...
2121 (A51244)
2121 (A51244)
