/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,901
You mean it wasn't clean enough already???
I've only washed mine once. That was after spreading a tandem load of manure that was dumped in the wrong place. I told the neighbour that if they wanted that done again, don't dump it blocking the only access point.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,902
Cut up an apple tree that fell over last summer. Finally able to do heavier work after breaking my ankle. Chipped all the limbs with the 3 point chipper. Used the forks to haul the 4’ chunks away.
Then mowed the entire area that couldn’t be mowed before. I use my wheel horse 314 for a brush cutter. Not really brush, but high grass, multi flora rose, barberry.
Trying to find a tiller so I can turn the ground over and replant as actual lawn.
Guy had a running bolens 1254? tractor with a tiller for sale locally. I was on vacation and missed it. I think it was $350. Still pissed about that.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,903
Depending on soil conditions, a 6" bucket can be hard to empty.
I have heavy clay soil. And, unless it's bone dry, my 6" doesn't empty well.
I learned to schedule those projects for the driest time of the year. Then, it goes quite well.
The BXpanded design has shallow sides which will help with emptying.
If sticking is a problem, wait for dry conditions.
Shaking the heck out of it, is likely to loosen your bushing's up in a hurry.
If it sticks, I just tip it upside down and just tap it on the ground ...
Gets "most" of it out ...
One thing to be aware of using both the Quick-On and the narrow 6" bucket ... It's "possible" to snatch the pin out of the Quick-On ... !
I did add one of Kenny's Bolt on Hooks to the factory bucket ... Comes in handy! Even though I had to do a bit of digging on this 25 plus year old set post, setting the bucket on the ground, and "rolling " it back, got it started up ...
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,905
Caught a thieving opossum in my barn this morning ... So I switched out the QH for the BH and headed out to the fence corner where I plan to plant an Forsythia bush in the spring . . . We've had less than 2/3" of rain in the last 2 months, and the clay is quite hard, so I brought a long my 6" bucket and the ripper . . . Gonna make some awesome opossum fertilizer!
The factory 12" bucket was having trouble digging . . .
So I tried the 6" . . . as this was the best the 12" did after many tries!
A little bit better, but not much, and it didn't like the sod ...
Put the ripper on and LOOSENED it up!
Then switched back to the 12" and cleaned it out!
It's only 30" - 32" deep ... I dropped the fertilizer in, then tossed the sod in, then back filled ...
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,906
I then came down to the garage for some maintenance on poor Little Baby Fergie ...
A few weeks ago I was out watering and was backing up on uneven terrain and it started to spin, I put it in 4X4 still wouldn't go, locked in the rear axle ... Still spun ... Then I noticed both front tires were pointed out! My left side tie rod end had popped out, the nut was missing ... I had to finish ... So I did a "field repair!
The threads were already buggered up, so I grabbed a few washers and some wire and tied it together ... And ordered two new tie rod ends, as both were pretty tore up from brush hogging over multi-flora ros
es!
I also stuck a piece of wire though the right side one, as that didn't have anything securing the castle but, not sure if it ever had one, or if I snatched it out while brush hogging ... ? Does your have a cotter pin in it?
The tie rods don't come with new nuts, washer or cotter pin, they are separate ...
The old one was not really wore out, but I didn't mind tossing it in the trash!
Got both sides replaced, and used a hypodermic needle on the end of my grease gun to give both 4 pumps of grease ...
Then greased the rest of the TLB, as I have a few pins that need me to move the boom to get them to take grease, .. . Then switched back to the QH and ready to water now that the totes are almost filled ...
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,907
Got another 650 gallons of water out to the trees today ... Takes about 50 minutes running the well and garden hose to fill the trailer tote to about 150 gallons, compared to 1 minute if there is water in the creek I can pump out!
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,908
Got to swing by home again today ... Gave Little Baby Fergie a workout!
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,909
Last night shortly before coming in from my creek project I noticed the BH control tower was wobbly, rocking forward and back, this morning I took the plastic cover off, and 2 of the 4 mounting tabs have cracked!
While I could weld it mounted on the tractor, I prefer to wait until I take it off to weld it ... In the meantime I used a rachet strap to secure it!
I then went out to work on my Kubota, Little Baby Fergie helped me carry stuff from the garage ...
I then loaded her with supplies to put a bag of concrete around two of my corner survey pins, one is down in the creek! I wanted to do it while it is still dry!
I dropped a lug nut over the piece of rebar, then added two old bolts, to increase the metal content, to make finding later easier
Then went out front, while there is a 4" steel fence post right there, I figured it would preserve it, plus make trimming around it easier ...
Then we went back to the creek project ... More details in link in previous post ...
While down there putting the ripper tooth on, I noticed the BH said "Made in USA" ... I know the tractor was made in Indonesia (2021) so I looked at the loader, and was disappointed when I read "Made in PRC" which I interpreted as "Peoples Republic of China"! What's yours say?
Nevertheless ... The loader is quite simple, and has been holding up good!
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,910
Started out this morning with lifting the Z-TRAK up to touch up the blades ...
Then had to rescue the John Deere due to operator error! I was trying to get some of weeds that had grown up under the deck, and bumped, and broke some of the railing with the ROPS, which pushed the nose into the wall! I couldn't back up, just spun!
So Little Baby Fergie to the Rescue!
All better now!
Probably didn't help that I had been collecting rock out of the front drainage ditch earlier ... ? I did dig quite a hole though, for turf tires!
Forklift Safety Basket Attachment (A53421)
Forklift Safety...
2015 Ford Transit 150 Cargo Van (A53422)
2015 Ford Transit...
2007 CHEVROLET C4500 DUMP TRUCK (A51406)
2007 CHEVROLET...
2000 Trail King TK70SA-48.2 T/A 43 Ton Hydraulic Slide Axle Step Deck Trailer (A52377)
2000 Trail King...
2020 BOBCAT T76 R SERIES SKID STEER (A52705)
2020 BOBCAT T76 R...
2007 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2007 DRAGON 150...
