DK 45 Losing Power under load
   / DK 45 Losing Power under load #31
Simple....fuel filter or debris plugging fuel port in tank.
   / DK 45 Losing Power under load #32
Does nobody read the entire thread before stating their expert analysis???
He clearly stated what fixed it on Saturday and it wasn't fuel filter for everyone that posted that as a solution since his post!
   / DK 45 Losing Power under load #33
Yes he did. And the solution does not seem to match the power loss problem. Id sure like to see some expert analysis of that.
Ok so for those following along in my saga....replaced the air filter...no improvement. Replaced fuel filter...no improvement. Replaced hydrostatic and hydraulic filters and drained and changed hyd transmission fluid....Success. My only problem now is trying get an accurate reading on the dipstick. I only put about 9 gals in but got about 10.25 gals out?? At 9 gals the level is midway between high and low on the stick. Going to have a couple of friends also ready the stick and see if they see the same thing...manual says it takes 11.8Gal...so little bewildered...but at least its working.
   / DK 45 Losing Power under load #34
I think the OP changed dirty air and fuel filters to solve his problem.
I service my tractors in the spring regardless of hours. Less than 100 hrs yearly on 2 tractors.
Good practice. We do the same
   / DK 45 Losing Power under load #35
2014 DK45 with a vineyard CIMA airblast sprayer on the 3 pt. Running at 2500 RPM which is the PTO at 540. Flat ground not seeing any issue, however going uphill in low gear at 2-3 mph and the tractor is fine but after about 100 feet going up a 10% slope the RPMs drop and the tractor slows and sounds like its really lugging. Stop forward motion and the RPM comes back up but as soon as I try to move forward the RPMs drop. Turn off the PTO and the RPMs come right back to full power and I can drive up the hill with no issues.
I am guessing it’s a hydraulic issue since this tractor model is a hydrostatic transmission so the hydraulic system is heavily used for everything. I don't think its a fuel issue but it could be the fuel filter...
I am guessing its a hydraulic issue since this tractor model is a hydrostatic transmission so the hydraulic system is heavily used for everything. I don't think its a fuel issue but it could be the fuel filter...
   / DK 45 Losing Power under load #36
For what it’s worth, my Mahindra was doing exactly the same thing and I suspected fuel issues. After replacing both in-line fuel filters (no help) and researching all the hydraulic related possible problems, the dealer suggested checking the in-tank fuel strainer. It was not easy to get to but when I dropped it out it was covered in gel-like gunk and debris. Cleaned and reinserted, tractor runs like new…
   / DK 45 Losing Power under load #37
Reading this with much interest and taking notes! My Kubota L3540 is doing the exact same thing, the strainer in the bottom of the tank was plugging up (best I could tell) finally
got a diesel transfer pump and “vacuumed” the tank(see pics) and it helped a bit. Still works full power on flat land or downhill but as soon as I go uphill RPMs drop way off!! Oh, this is pulling a mower. Driving me crazy!
   / DK 45 Losing Power under load #38
My first thought is fuel delivery problem. I don’t think a hydrostatic trans would wait 100 feet to have a problem.
Do you have a tachometer? Is the rpm drop gradual over the 100 feet, or sudden at about 100 feet?
   / DK 45 Losing Power under load #39
How long have you had this tractor and that sprayer hooked together?
Looking at those sprayers the smallest requires 25 PTO just for the sprayer, then add in the Hp required to move your tractor up that hill in addition to powering the sprayer.
Trying to maintain that 2-3 mph to keep the same sprayer coverage may require more tractor Hp then you have.
It may be a fuel problem or even an air flow restriction.
I doubt that it is a hydraulic problem, your tractor has a hydrostatic transmission which consists of a hydraulic pump and motor in a combined unit for ground work. Your PTO is strictly mechanical in power transmission, your hydrostatic transmission is separate from the PTO and the other tractor hydraulics.
The tractors hydraulic pump(s) supply hydraulics for cylinders and such and your 2 point hitch and power steering.
It is also the charge pump supply for your transmission, in other words it makes up fluid for what "leaks" from the pump/motor it does not power the tractor.
I agree about HP requirements. If the problem isn’t fuel delivery, I think it’s not enough HP.
   / DK 45 Losing Power under load #40
I have a small Mahindra, the fuel filter supplied by Mahindra was way to small, it would suck itself up and starve the motor in a very short time, and show now particulate in it. i manufactured a manifold for a spin on fuel filter and mounted it on the opposite side in the same loc as the orig., removed the filter from the orig (now just a water catcher) and haven't had a problem since. change the spin on every year or so and it's been several years no issues.
Mower King Brush Cutter (A53317)
Mower King Brush...
Deere 35P (A53317)
Deere 35P (A53317)
Bunker Rake (A59228)
Mini John Deere Truck (A55853)
Mini John Deere...
2021 UTILITY VS2DX 53FT DRY VAN (A59575)
2021 UTILITY VS2DX...
2023 WRANGLER 5500T ARTICULATED WHEEL LOADER (A58214)
2023 WRANGLER...
