Servicing my YM 1600
   / Servicing my YM 1600 #1
Spectre07
YM 1600
New to working on tractor. What is the purpose of two oil fill ports on the valve cover and a third on the assesory cover on my YM 1600? I figured they must use this valve cover for other applications so I change the oil today using the fill port on the assessory cover, then cleaned the tractor. When I started it, I found an oil leak from my valve cover gasket, and it was definitely not fresh oil. Is it just a couple ounces of old oil that didn't drain out of the valve cover, or is there another oil reservoir I need to attend to?
   / Servicing my YM 1600 #2
Please re-post you question in the pre-Y2K (year 2000) Yanmar tractor section found here,
2010 John Deere TX Gator 4x4 Utility Cart (A52377)
2010 John Deere TX...
2011 Kenworth T800 Water Truck (A54865)
2011 Kenworth T800...
UNUSED Heavy Duty Ratchet Strap Set (A53117)
UNUSED Heavy Duty...
2015 Ford F-350 Dump Truck (A51692)
2015 Ford F-350...
2022 Weber MT CF2A Plate Compactor (A55851)
2022 Weber MT CF2A...
2013 Chevrolet Malibu Sedan (A51694)
2013 Chevrolet...
