off road diesel
   / off road diesel #1
arthurqian2003
TYM T494H, John Deere 2025R
Used to be just get regular diesel from gas station as only use less that 5 gallon per month. Now start to work on the land and used 60 gallon last month. Just want to know where and how to buy red diesel? location: Columbia, South Carolina. Thanks.
   / off road diesel #2
Every gas station in our small home town has a pump with red dyed diesel... You might have to ask around your town (or the attendant). Sometimes it's in the back of the store!!! For sure, it's off to the side... Not out front!!!
   / off road diesel #3
Here there is not a single station that delivers. There is a place that sells it but they are setup to deliver and won’t fill 5 gallon cans.
   / off road diesel #5
Our local COOP has an off-road fuel pump at the stations that are near the farming areas. $.11 a litre cheaper (40 to 50 cents a gallon). The pump is kept locked and you have to go inside to get it unlocked.
   / off road diesel #6
If you have to go far to get it, just remember you’re putting wear & tear on your truck, and burning fuel to go get it.
   / off road diesel #8
Sounds like you need to have a bulk 200~275 gallon tank so you can have red fuel delivered.
Then starts the battle of keeping that fuel clean and free of moisture. Plus the cost of setting up everything (tank, pump).
If I was the OP, I’d install tank in bed of truck and fuel up from there. I wouldn’t know what to do without mine. It’s an essential tool.
   / off road diesel #9
Just north of Columbia the BP in Blythewood (by Langford Road and Hyw 21) has off road diesel.
I also believe that there are a couple places on Hyw 321 that sell it too.
I’m sure there are others places too.
This search shows some other options.
   / off road diesel #10
If you have oil heat, do what I do and pump it out of your oil burner storage tank. Around here anyway, home heating oil is red ULS #2, the same as ORD. Check with your supplier first to see if it contains any additives. You might have to add anti gel or anti bacterial agents if you store your equipment outdoors.
2015 Ford Taurus AWD Sedan (A54815)
2015 Ford Taurus...
72 Inch Dual Cylinder Skid Steer Grapple (A55851)
72 Inch Dual...
2016 R and R Products 331 LP Reel Mower (A51694)
2016 R and R...
2011 MACK Tender Truck w/ADAMS Rear Discharge Bed Auger (A55314)
2011 MACK Tender...
2023 Vivid EV Electric Cart (A55853)
2023 Vivid EV...
2017 Ford F-150 Crew Cab Pickup Truck with Liftgate (A55852)
2017 Ford F-150...
