9 Worst Things You Can Do to a Diesel Engine
   / 9 Worst Things You Can Do to a Diesel Engine #82
Diesels generally are in to 40:1 - 50:1 compression ratio
Do the mfg's know that? I bet you that would be BIG news to them!!
SR
OK, I was off a bit (more than double!) but I did add the disclaimer of "IIRC"! But a diesel is still nearly double that of a gasser!
However I did get the compression psi correct 😁
Glad I'm not perfect, what a boring life that would be! 🤠
   / 9 Worst Things You Can Do to a Diesel Engine #83
Diesels generally are in to 40:1 - 50:1 compression ratio, and well over 400 psi in a compression check ... IIRC ...
There is a reason there is a hefty upcharge for a diesel engine in a pickup truck over the standard gasser ... They cost more to make!
I was going to call you out on those numbers but someone beat me to it.
   / 9 Worst Things You Can Do to a Diesel Engine #84
Get with the program, are you awake yet? :rolleyes:
(I already acknowledged I was wrong ...) I WAS right on the PSI, and that the fake intelligence info that gassers were built tougher because they were under more pressure was a bunch of bulloney ...
   / 9 Worst Things You Can Do to a Diesel Engine #85
With starting fluid I was always told to crank the engine over as you spray the starting fluid if possible this way there is diesel fluid in the cylinder not just starting fluid. A mechanic suggested that to me a long time ago.
   / 9 Worst Things You Can Do to a Diesel Engine #86
  • Letting the fuel tank run low. ...
  • not keeping up with oil changes. ...
  • Using the wrong type of fuel. ...
  • Cold starts without proper warm-up. ...
  • Overloading the engine. ...
  • Skipping coolant changes. ...
  • Neglecting filter maintenance. ...
  • Ignoring warning lights. ...
  • Failing to keep the engine clean.
FWIW: the following came from a diesel tech course put out by UTI earlier this year. Part of their 45 week diesel training course
Not keeping up with oil changes
Skipping oil changes is one of the fastest ways to wear down your diesel engine. Over time, engine oil loses its lubricity as it breaks down from heat, pressure and contamination. As the oil ages, it becomes less effective at reducing friction, absorbing heat and suspending harmful particles. In diesel engines, where internal pressures and operating temperatures are often higher than in gas engines, this breakdown happens even faster.
Contaminants like soot, fuel dilution and metal particles can accelerate wear on vital components such as bearings, pistons and turbochargers. Sticking to a regular oil change schedule based on your engine’s workload and manufacturer guidelines is essential to maintaining performance, preventing costly damage and extending the life of your diesel engine.
Running a diesel engine on a near-empty tank can cause serious problems. Sediment and contaminants naturally settle at the bottom of the tank, and when fuel levels drop, these particles can be pulled into the fuel system, clogging filters, damaging injectors and reducing fuel flow.
But the bigger concern is air entering the fuel system. Diesel systems rely on consistent pressure and flow, and introducing air can lead to hard starts, engine misfires and, in some cases, injector damage due to improper lubrication and cooling.
Low fuel levels can also increase the risk of moisture buildup, especially in environments with temperature swings. The more space in the tank, the more room for condensation to form, which can lead to microbial growth and fuel degradation. To prevent these issues, it’s best to keep your diesel tank at least a quarter full whenever possible.
Diesel engines require diesel fuel, plain and simple. Accidentally using gasoline in a diesel engine can cause severe damage. Gasoline lacks the lubricating properties that diesel fuel provides, which are essential for protecting high-pressure components like fuel injectors and the fuel pump. Without proper lubrication, these parts can quickly overheat, seize or wear prematurely.
In addition, gasoline combusts differently than diesel. It can ignite too early in the combustion cycle, causing engine knocking, misfires and potentially catastrophic damage to pistons and valves. Even a small amount of gasoline can disrupt the entire fuel system and may require a full flush to prevent long-term issues.
Using the wrong grade of diesel (e.g., #1 vs. #2, or off-road vs. on-road diesel) can also impact engine performance and emissions compliance. Always double-check the pump before refueling and make sure you understand which fuel type your vehicle or equipment requires based on climate, application and manufacturer recommendations.
Diesel engines don’t respond well to cold starts, especially in freezing temperatures. Starting the engine without allowing it to warm up can cause incomplete combustion, rough idling and excessive engine wear. Cold temperatures thicken both diesel fuel and engine oil, making them harder to circulate through the engine. Thickened oil struggles to reach critical components quickly, increasing friction and wear during those first few moments after startup.
Diesel fuel can also gel in extremely low temperatures, restricting flow to the injectors and fuel pump, which may lead to hard starts or stalling. This is especially problematic without the right winter blend or fuel additives.
To protect your engine, use block heaters, glow plugs or intake heaters to warm the engine and fuel system before starting. Letting the engine idle for a few minutes gives oil time to circulate and ensures the fuel reaches the right temperature for proper combustion, reducing stress and wear on internal parts.
Pushing your diesel engine beyond its limits by hauling loads heavier than it’s rated for can cause excessive stress and long-term damage. Overloading increases engine workload, leading to higher operating temperatures, reduced fuel efficiency and accelerated wear on critical components.
When the engine is forced to work harder than intended, internal components like pistons, bearings and valves experience more friction and pressure, which shortens their lifespan. The added strain can also affect the transmission, drivetrain, suspension and braking systems, putting your entire vehicle at risk.
Prolonged overloading can even lead to thermal breakdown of engine oil, decreasing its effectiveness and further compounding wear. To ensure safe and efficient operation, always stick to your vehicle’s recommended weight limits, including the gross vehicle weight rating (GVWR) and tow rating, and evenly distribute loads to avoid unnecessary stress on the engine and chassis.
Coolant helps regulate engine temperature and prevent internal corrosion, making it critical for diesel engine health. Skipping coolant flushes allows the coolant to degrade over time, reducing its effectiveness and exposing the cooling system to serious risks.
When coolant breaks down, it loses its anti-corrosion properties and can become acidic, leading to rust, scale buildup and clogged coolant passages. This restricts flow and reduces heat transfer, causing the engine to overheat. Degraded coolant can also damage the water pump, radiator and head gasket, potentially resulting in costly repairs.
Signs of bad or failing coolant include:
  • Rusty, sludgy or discolored coolant
  • Persistent overheating
  • Coolant leaks or low levels
  • Sweet smell under the hood (indicative of a leak)
Regularly flushing and replacing coolant based on your engine’s maintenance schedule helps keep temperatures stable, protects vital components and extends the life of your diesel engine.
Diesel engines rely heavily on clean air and fuel, making filter maintenance critical. Dirty air filters reduce airflow, leading to poor combustion, increased fuel consumption and power loss. Clogged fuel filters can restrict fuel flow, starving the engine, damaging injectors and causing hard starts or stalling.
Over time, neglecting filter maintenance doesn't just impact performance; it can lead to long-term engine damage. Insufficient air or fuel flow can result in incomplete combustion, which produces more soot and unburnt fuel. This buildup can clog exhaust gas recirculation (EGR) valves and coolers, reducing their efficiency and contributing to higher emissions, rough idling and even EGR system failure.
In severe cases, dirty filters can lead to increased crankcase pressure and contamination of engine oil, accelerating internal wear.
Dashboard warning lights are there for a reason. Ignoring signs like the check engine light or glow plug warning can turn minor issues into major repairs. Address problems as soon as they appear to prevent further damage and avoid expensive breakdowns.
Dirt, grime and oil buildup can hide small leaks and lead to overheating or contamination. A clean engine compartment helps you spot issues early and ensures proper airflow for cooling. Regular cleaning also extends the life of hoses, belts and seals.
Well on coolant, a heavy engine antifreeze with the additive that stops pitting of the cylinder liners or the cast cylinder block.....forget the name of it.
Not getting it out at least every once in a while and working it hard for an hour or so, then changing the engine oil and filter.
Cranking it up every month or so to keep the oil particles in suspension, not deposited on the bottom of the oil pan as sludge.......to name a few.
   / 9 Worst Things You Can Do to a Diesel Engine #87
Anti-Cavitation additive
Agree. Not good to let them sit too long.
2005 CHANDLER 500 BBL FRAC TANK (A58214)
2005 CHANDLER 500...
ALLMETAL MOBILE PRESSURE WASHER (A58216)
ALLMETAL MOBILE...
8' X 28' S/A OFFICE TRAILER (A52708)
8' X 28' S/A...
UNIVERSAL MOUNT GRAPPLE BUCKET (A52708)
UNIVERSAL MOUNT...
2015 FORD F-350 XL SUPER DUTY SERVICE TRUCK (A51406)
2015 FORD F-350 XL...
SKID STEER ATTACHMENT MULCHER (A58216)
SKID STEER...
