Zero Turn Rear Tire Suggestions
   / Zero Turn Rear Tire Suggestions #1
kf4uda
Middle TN
NH TD5030, 861 Ford Powermaster, CaseIH Farmall 35A, 555A Ford Backhoe, S150x SnapperPro ZTR, Polaris Ranger XP800
I have a SnapperPro S-150x zero turn mower that I have been running for a few years now. It is time to replace the rear tires and I am looking for suggestions on the replacements.
Tire size is 22x11-10. The current tires are Carlisle Turf Master. They have been OK tires but I wouldn't mind having slightly more traction (hopefully without tearing up my yard).
Thanks for your time!
   / Zero Turn Rear Tire Suggestions #2
Maybe an ATV tire that is not a full blown knobby. On an image search, I see a Nanco N244 which would be a notch up from the turf savers and hopefully not too aggressive. They have knobbys too that have a chevron pattern in between the lugs. Lots available in this size.
Thanks! I will take a look at them.
   / Zero Turn Rear Tire Suggestions #4
When I went to a Carlisle At-101 chevron style tire my mower became a whole new machine. i tear up less than with the Carlisle Turfmaster IIs because I spin so much less. I would never go back.
I bought a different mower - same brand (Deines) but went from a 60" to 72" deck and two back wheels. It was used and has turfs on it. I used it once and decided tires are getting changed.
   / Zero Turn Rear Tire Suggestions #5
x2 on the AT-101 tires.
IF you know how to run your mower, a more aggressive tire actually does LESS turf damage.
   / Zero Turn Rear Tire Suggestions #6
Another idea might be the Carlisle WT300. They’re a mini R4 tread.
WT300 Turf Tires
I think that I am sold on the AT-101 style tire (chevron bar). Carlisle doesn't show the size that I need. Kenda makes the same style tire and has the size that I am looking for: Amazon.com: Kenda K472 Bias Tire - 22x11.-1: Automotive
Does anyone have any experience with Kenda?
   / Zero Turn Rear Tire Suggestions #8
Kenda is known brand and has been used on OEM equipment. Definitely looks to be a step up!
   / Zero Turn Rear Tire Suggestions #9
Those Kenda K472's are fine. Also, OTR makes a bar tire in the 22x11-10 size. They are (or at least used to be) OEM on Grasshopper mowers.
   / Zero Turn Rear Tire Suggestions #10
1989 Ford FT900 T/A Cab and Chassis Truck (A51692)
1989 Ford FT900...
2019 Chevrolet Tahoe Multipurpose Vehicle (MPV) (A52377)
2019 Chevrolet...
2009 Lincoln MKS Sedan (A51694)
2009 Lincoln MKS...
Wells Cargo Enclosed Trailer (A53117)
Wells Cargo...
Manac Walking Floor Trailer (A50322)
Manac Walking...
