Ford 1710 (and others) Hydraulic Power Beyond Adapter Plate
   / Ford 1710 (and others) Hydraulic Power Beyond Adapter Plate #1
tedward4
Rochester, MN
'84 Ford 1710, '87 Ford LGT 14D
Hi Everyone,
A while back I posted some pics of the rear remote valve I made for my 1710. See the last pic below, and here's a link to the original post:
https://www.tractorbynet.com/forums/new-holland-owning-operating/344051-ford-1710-rear-remote-valve.html
I've had several people see that post and ask for help with their rear hydraulics. Most recently, a member requested help with plumbing a backhoe to the tractor hydraulics. He didn't need the valve mounted to the tractor, but just the bower beyond capability. He also didn't like plumbing into the diverter valve in front of the right footrest and running hoses to the back of the tractor. After unsuccessful searches for a HV4950 or SML25854 adapter plate, I ended up machining an adapter. I originally thought that this adapter would only fit the 1710, but it looks like it will fit the 1100-1900 (with slight modification) and 1110-1910 tractors with position control 3pt. Hopefully after all the messing around with the hydraulics I can be helpful to others looking to add rear hydraulics.
   / Ford 1710 (and others) Hydraulic Power Beyond Adapter Plate #2
Similar to the 1700 adapter.
Yep, exactly what I was going for except I put a second set of ports on the top so you can run hoses to the back of the tractor more easily. From my looking, those 1700 adapter plates you showed are really hard to find from either NH or aftermarket.
   / Ford 1710 (and others) Hydraulic Power Beyond Adapter Plate #4
Oh ya Messick has them also.Screenshot_20200423-123219_Chrome.jpegScreenshot_20200423-123258_Chrome.jpeg
   / Ford 1710 (and others) Hydraulic Power Beyond Adapter Plate #6
I had to call them and they located 1 through a vendor.
What would a kit like this cost?
$150 shipped. It includes all the fittings, orings, and hardware to mount. I made up 3 of them so have 2 left on the shelf. Send me a PM if you're interested.
   / Ford 1710 (and others) Hydraulic Power Beyond Adapter Plate #8
Are you mounting the relief valve to the block adapter?
I've only seen the 1710 tractors with relief valve up by the right footrest. 1700 tractors seem to have it mounted on the quadrant cover. I have a version of the adapter plate for the 1700 as well.
   / Ford 1710 (and others) Hydraulic Power Beyond Adapter Plate #10
Ya because the adapter plate is between the relief valve and control valve plate on my 1700.
JOHN DEERE/UNVERFERTH 1700/330 LOT NUMBER 13 (A53084)
JOHN...
2011 Mack CHU613 T/A Wet Kit Day Cab Truck Tractor (A51692)
2011 Mack CHU613...
John Deere 700 Hydraulic Hay Rake - Durable Side Delivery Rake for Efficient Windrowing (A53472)
John Deere 700...
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2016 Ford F-150...
City of Lakeland (A51691)
City of Lakeland...
Trojan 8T-50 46in Hydraulic Thumb Excavator Attachment (A51691)
Trojan 8T-50 46in...
