Taking out a stump, a BIG stump
   / Taking out a stump, a BIG stump #1
karmakanic
NE Texas
Kubota L35 TLB, John Deere 550 dozer, Cat D-2 dozer, Allis Chalmers HD-11 dozer
"Honey, isn't it about time you took out that old stump that's in the middle of my daffodil field. I'm getting tired of mowing around it, and I can't get the poison ivy cleared out cause of the roots." So spoke my lovely significant other and head daffodil planter.
Hmmm,,,well I guess so. It's been rotting there for about 4 years now, hopefully mother nature's little ground living vermin have softened it up enough. I knew better then to go after it right after we had cut it down. It was a granddaddy bur oak when it died, and wasn't going to give up it's foothold easily.
But it certainly didn't look that intimidating at first glance. See attached photo.
Well,,,like the proverbial iceberg, it's what's under the surface that counts. Here's the root ball exposed. Ms. head daffidol planter stands 5'6" tall and kindly consented to climb in the hole for perspective.
Finally got the root ball broken loose. Now, how to get it out of the hole?
Well,,,slinging a chain around it and dragging it out ain't gonna work,,,tire spin city,,,
   / Taking out a stump, a BIG stump #5
One idea for getting the stump out of the hole is to roll it to one side, then push dirt into the other side. Keep rocking it back and forth onto the dirt pushed back into the hole. Slowly it will get higher and higher. I raise large boulders out that way. With stumps, I fill in around them so they are below ground level. I don't try to get them out.
So, let's worry on it with the backhoe bucket for a while,,,just worry that old thing until it gives up,,,
Finally got the bucket teeth in the right toe hold and split the trunk into two pieces, here's the first half coming out of the hole now.
And here's the second half coming out of the hole.
   / Taking out a stump, a BIG stump #9
Nice project you got there along with your L35 (SWEET). If I were you I would get your 550 out and toss her around awhile and then put the ole stump to rest somewhere. Looks like you got plenty of toys to play with that's for sure. LOL
Darin
Great pics too with step by step.
And finally, job finished,,,
The area now safe for mowers and daffodil planters.
2018 Terex RL4 4000W Towable Light Tower (A49461)
2018 Terex RL4...
2021 CATERPILLAR 259D3 SKID STEER (A51242)
2021 CATERPILLAR...
2011 L3 GENERATOR SET (A51222)
2011 L3 GENERATOR...
2019 POLARIS RANGER XP PROSTAR 900 HD DOHC UTV (A51406)
2019 POLARIS...
2023 John Deere 8R410 MFWD Tractor (A51039)
2023 John Deere...
71054 (A49346)
71054 (A49346)
