00 grease
/ 00 grease #2
I am using this in a woods gear box and has not leaked out. Had been using gun grease and 90wt until I replaced that this summer.
/ 00 grease #3
i have used both 0 and 0 ep greases in many applications from gearboxes on mowers ( even some made for grease! ).. to older mowers with weeping seals. Also in steering boxes.
I've not used that brand.. but IMHO. the weight is the important part.. check to see if it is EP.
Me 00 i use is a stens product similar to a snapper 00 grease used in rear ends of some lawn equip.
JD makes a corn header greas 0EP as well.. sold byt he tube or case. as stated.. used in corn header boxes.
/ 00 grease
Thanks guys. It does not say ep on it or on the spec sheet, but it say's it meets or exceeds specs for JD 360 and 380 cornehead spindle grease and is appropriate for gear boxes. The price on this stuff is appealing as it was only $4.99 for a quart the last stuff my dad got was $7.99 for a tube of I think 14 or 16 ounces. Gonna give it a try as I am going though about a quart every two weeks on leakage. Replaced the seal twice and not gonna do it again.
/ 00 grease #5
Where are you guys finding pour able grease. I've checked the car parts stores, and Tsc, even walmart, but haven't found any. Do you Have to go to an ag/equipment dealer?
/ 00 grease #6
if it's a replacement for jd cornhead grease.. it is likely at least mild ep. jd ch grease is a NLGI 0 EP poly urea grease
/ 00 grease
This is from TSC. This was not with the oil or grease, it was in the trailer bearing section.
/ 00 grease #8
i'll have to see if my tsc carries it.
currently i pay about 7$ a quart from the lawn mower repair place down the road.
/ 00 grease #9
I have a Ford-917L flail mower that leaks 85w140 all most as fast as you pour it, so I'll have to look in the trailer section of a couple local TSCs.
/ 00 grease #11
Well, a bit of over statement. Probably go from full to empty over an hour of mowing.
/ 00 grease
At that rate it costs you more in oil than it probably does fuel to mow for an hour.😠
/ 00 grease #14
I bought the "00" at TSC last week. They had to look it up computer because the clerk and I were looking in grease and gear oil area. It was in the three point parts area.
/ 00 grease
It was in the trailer\ wheelbearing section in our TSC so it must vary. I just happened on it as I was browsing as I looked several other times in the grease area.
/ 00 grease #16
still worth a look!
/ 00 grease #17
I just bought 1 quart of Super-S 00 grease from TSC in Starke, FL. $4.99 before taxes. It was in the lube section, but on the very top, and over by gear oils, not greases. My recipe lists it as "Spindle Grease". Don't know how TSC is about standardizing stock area to areas; maybe some have more ag stuff in ag areas and more garden in the suburban stores?
/ 00 grease #18
i'm checking today!
2019 ISUZU NPR 4X2 S/A 20FT BOX TRUCK (A59910)
2019 ISUZU NPR 4X2...
2021 John Deere 6120M Tractor (A63109)
2021 John Deere...
2016 CATERPILLAR 416F2 BACKHOE (A62129)
2016 CATERPILLAR...
YALE VERACITOR 50VX STRAIGHT MAST FORKLIFT (A63276)
YALE VERACITOR...
2007 Grove RT530E-2 4x4 30 Ton Rough Terrain Crane (A61572)
2007 Grove...
Freightliner Tender Truck - Adams Tender (A63118)
Freightliner...
