'04 RTV 900 transmission problems, where would you begin?
   / '04 RTV 900 transmission problems, where would you begin?
If the piston slipper and swash plate surfaces are not perfect you will not have a successful repair.
I've searched the WSM and haven't been able to find anything called a "piston slipper". Are you talking about what they call the cylinder block that the pistons go in?
   / '04 RTV 900 transmission problems, where would you begin? #12
Terminologies vary, mine does not align with Kubota. The surface of the piston that contacts the swash plate.
These have a thrust bearing that is against the swash plate that the piston contacts.
2014 PETERBILT 388 VACUUM TRUCK (A55745)
2014 PETERBILT 388...
CAT 308E2CR (A53314)
2004 Ford F-250 Liftmoore 2,700 LB 1 Ton Crane Service Truck (A55788)
2004 Ford F-250...
2014 Ford Taurus AWD Sedan (A54815)
2014 Ford Taurus...
2001 AMADAS 2100 LOT NUMBER 251 (A53084)
2001 AMADAS 2100...
2005 Jeep Wrangler 4X4 SUV (A55758)
2005 Jeep Wrangler...
