'04 RTV 900 transmission problems, where would you begin?
   / '04 RTV 900 transmission problems, where would you begin?
If the piston slipper and swash plate surfaces are not perfect you will not have a successful repair.
I've searched the WSM and haven't been able to find anything called a "piston slipper". Are you talking about what they call the cylinder block that the pistons go in?
   / '04 RTV 900 transmission problems, where would you begin? #12
Terminologies vary, mine does not align with Kubota. The surface of the piston that contacts the swash plate.
These have a thrust bearing that is against the swash plate that the piston contacts.
Wagon Wheel Rocking Chairs (A55758)
Wagon Wheel...
2019 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
Kubota GF1800 (A47477)
2003 International 7400 T/A Heil 12 CuYd Dump Truck (A51692)
2003 International...
2016 Ford Fusion SE AWD Sedan (A53424)
2016 Ford Fusion...
