08 B7800 Possible Purchase
   / 08 B7800 Possible Purchase #1
Skier8251
Jax FL
JD 2440
Hey guys, long time lurker, first time poster..
So, Looking to get a small tractor for property.
I am considering an 08 Kubota B7800.
What should I be aware of? Anything specific to this model?
Was also curious as to if this would take a front mounted Blower?
Thanks for the Help in advance!
   / 08 B7800 Possible Purchase #2
Welcome to TBN.
   / 08 B7800 Possible Purchase #4
Ive had my 7800 since 2003 and it has been bulletproof. The only repair in all the years was one weeping rear axle seal. The only drawback I have found is the 1/4 inching 3 point. It takes some time to learn how to grade well with it.
   / 08 B7800 Possible Purchase #5
I have essentially the same tractor. Probably the single best tool that I've ever bought. I have the 6' belly mower and loader. Cleared snow with the FEL and a REAR 3-point 64" blower with it for years and it did great! It's a fantastic mowing machine. Also perfect size for a 5' tiller. Easy on fuel.
There was a member on here a couple months ago looking for a front snowblower for his. Here's the link.
He wasn't having a good time finding a front snowblower and dealers weren't able to locate the equipment either. If I were set on a front snowblower, I'd find a tractor package that included it and not try to source it after the purchase -- ESPECIALLY in today's tight supply-side environment. Since they're designed specifically for each machine, they're also not as easy to sell as the more universal-fit 3-point units. I think when someone has a front blower it tends to stay with the machine.
I will say that if I was starting over, I might have bought a smaller L series in order to get a little more weight. Otherwise the only knock I have on my B2910 is that the front bucket is pin-on style and not SSQA. But at the top of the B-series in HP and size, it's a very versatile machine.
   / 08 B7800 Possible Purchase #6
I had a B for like a decade, Got it the first year they were introduced.
No major issues. Seat switch got finicky over time, field repair on a cracked front axle.
Served us, well.
Just make sure the machine was cared for if you can.
Thanks for the great info! I did a bunch of searches on the front blower without much luck.. Not sure If I really need it, I could use just the bucket and or a blade in the back... Not 100% Sure as this is my first go with a tractor etc..... I say this 7800 for sale and heard they were solid tractors, but figured I would check with you all to see what the pro's thought.. ;)
CH4Ohio
What is the difference between Pin On and SSQA ?
Also I have Heard mixed emotions about the Transmissions on these things.... Any thoughts on that?
   / 08 B7800 Possible Purchase #8
You definitely want HST on a smaller tractor like the B7800. I'm not even sure if they offered that tractor with a gear shift.
Mine has the pin-on bucket, meaning that it's not at all easily swapped out for a snowplow blade, pallet forks, rock / manure bucket. Not a big deal on this size tractor really, but it would be nice to be able to drop the bucket and connect pallet forks every now and then. I would have also made a quick attach snow plow for mine if it had the SSQA setup.
The SSQA arrangement has a couple handles that you use to connect and disconnect the front bucket. This lets you quickly attach any implement that has a SSQA plate mounting surface. The advantage is that front attachments are universal using SSQA plates -- similar to 3-point implements fitting most any tractor (within reason).
With either setup, you can remove the entire FEL in about 5 minutes. Same with a belly mower. Very easy to remove and reinstall either as needed.
Thank you for the informative post! Good things to know. So another newbie question, can a mod package be purchased to change it to this without breaking the bank? LOL As you can tell I am new to the tractor game, so trying to soak up as much as possible and want to make sure I dont throw good money after bad with the purchase of a tractor
Pantropic Power Generator T/A Trailer (A46683)
Pantropic Power...
Garage Door Panels (A46502)
Garage Door Panels...
60in. Work Bench (A49339)
60in. Work Bench...
2019 John Deere 5075E (A47307)
2019 John Deere...
Toro Blower (A46684)
2107 (A46502)
2107 (A46502)
