1/4 hose for toplink
   / 1/4 hose for toplink #1
puckgrinder85
Platinum Member
WI
'13 Yanmar Lx4100
Anyone use 1/4 hose for a toplink over 3/8?" Im leaning to 1/4 for the size and minimal flow it will need, may be a bit of a restriction to slow down its movements. Anyone go this route with success?
   / 1/4 hose for toplink #2
1/4" hose is fine, it will not slow the use down that it makes any difference. I think that us suppliers of these premade hose kits use 3/8" hose because it is tougher than the 1/4" and therefore we as suppliers have fewer problems using 3/8" vs 1/4". You may find that you still want to get some restrictors to slow the ram down even more. ;)
   / 1/4 hose for toplink #3
I went with 1/4 and it still can move a little too fast. (That might have something to do with my 500 PSI piloted check valve, though.)
   / 1/4 hose for toplink #4
You can always add a needle valve and adjust it to your needs.
   / 1/4 hose for toplink #5
I always recommend 1/4" or TnT setups and grapples. Cheaper, more flexible, easier to route=win, win, win.
Its not really a matter of cylinder speed, I just thought it might be a desirable side effect of going with the smaller hose. I just gotta make sure my supplier can go from 1/4 line to a -8 JIC fitting. If not i'll have to stick with the 3/8 hose.
   / 1/4 hose for toplink #7
Strength of the hose has more to do with the quality of the hose you use, than the size. Hose comes in 1 wire braid, 2 wire braid or 4 wire. The more wires the stronger it is. Cheap 1/4" hose tends to be 1 wire and 3/8 tends to be 2 wire. As long as you get 2 wire hose, the 1/4" will be as strong as the 3/8" hose.
   / 1/4 hose for toplink #8
That should not be a problem
   / 1/4 hose for toplink #9
On a plow installation we found the lift/drop to be much too fast.
My solution was to install a male/female fitting that I welded shut and then bored a 3/32 hole thru the welded area.
Worked like a charm and cost, like $2.50 each!
   / 1/4 hose for toplink #10
The restrictors for my 3 point backhoe were a small hole washer dropped in before the hose was screwed on.
2017 Ford F-350 Crew Cab 4x4 Pickup Truck (A55788)
2017 Ford F-350...
2012 Toyota Camry Sedan (A55758)
2012 Toyota Camry...
1992 Effer 7600 2S Knuckleboom (A51691)
1992 Effer 7600 2S...
TOW BEHIND FINISH MOWER (A50324)
TOW BEHIND FINISH...
Husqvarna Push Mower (A47477)
Husqvarna Push...
2015 Chevrolet Silverado 2500 HD Crew Cab Pickup Truck (A55788)
2015 Chevrolet...
