100 HP ytractors
   / 100 HP ytractors #31
M5111 = 9039
MC105 = 12,943 lbs both are at the ends of the arms measurements, thats substantial, thats as much as most CUTs weigh lol or a CAR!!!
   / 100 HP ytractors #32
pretty common PTO setup for pulling out and reversing or putting in another hole with a cover plate on it to go from 540/1000 my buddies 2-105 white is like that, formerly oliver, been doing that for years
   / 100 HP ytractors
Is that front lift capacity, or rear, I haven't looked
The 75 hp new tractor comes with zero % financing, But you save $2500.00 by paying cash.
In other words. It ain't zero % as they get the interest up front lol
   / 100 HP ytractors
well, If I buy a McCormick. I won't be on this site much. I looked at the McCormick section and it's like a ghost town there
There is no McCormick owning /operating. No McCormick pricing
   / 100 HP ytractors #35
My neighbor bought one a couple years ago. Had a LOT of technical problems. Traded it off within a year.
   / 100 HP ytractors
Sadly, all brands have problems. Kubota, Deere, etc,.
I was at my Kubota dealer last week. he told me Factory reps from Kubota has been at the dealership trying to resolve DEF issues
There are several McCormicks around me . For one farmer up here has several. that's all he will buy.
If he had unusually high issues with them, he would trade and not buy another one
   / 100 HP ytractors #37
that was rear 3 point at end of arms numbers
   / 100 HP ytractors #38
i have experienced the new Deere issues - at 10 hours mmm gearbox had to be replaced = noisy ( deere admitted they had seen this and had one grenade ) - noise on mower deck - someone installed bolts wrong or maybe deere printed wrong in manual but rubbing when going over bumps and hitting driveshaft - first time in road gear ( entire chain is on here ) blew up pinion shaft, ring gear, on front axle, broke/bent main drive shaft from transmission to front differential, broke electric mechanism, been back to shop 3 times so far in 40 hours and 1 yr 2 mos. So they all can have issues - nothings perfect
and can you believe it, just heard from my mechanic on my 5088 some knucklehead twisted the line on the evaporator on the A/C line to the expansion valve and to get things right it had to be replaced - no wonder its been a problem not to mention they never replaced the old lines when converting to R134A and they were cracked and leaking as well. the foam under the roof is rotten too Grrrrrrr !!! I should write IH and get my money back - crap junk only lasted 37 yrs
next thing my sentry will go out - oh the drama
2016 CATERPILLAR 304E2 EXCAVATOR (A52709)
2016 CATERPILLAR...
2014 Ford Escape SUV (A55853)
2014 Ford Escape...
2001 TRIPLE E STEP DECK (A58214)
2001 TRIPLE E STEP...
2020 CAT 308 (A53317)
2015 TROXEL 150 BBL ALUMINUM VACUUM TRAILER (A58214)
2015 TROXEL 150...
New/Unused CFG Industrial MX12RX Mini Excavator (A57453)
New/Unused CFG...
