jenkinsph
Super Star Member
I have thought about having a propane standby generator but the house is at 8000' and pretty cold in the winter. So not only is it another engine to maintain but it also gets derated due to the altitude. But the tractor I am looking at has a turbo so loses no power due to altitude. The tractor is not going to get that much use so having it hooked up to the generator every now and then is not going to be a problem. Plus the solar system is going to have 3 days of reserve capacity for those cloudy days so I would only need to hook up the generator for a few hours every few days if there was no sun for an extended period, unless I wanted to use the shop. I don't use my shop all that often so running it off of the generator does not bother me on the fuel usage front and it keeps me from having to greatly increase the size of the solar system and associated cost.
Might want to consider a 3 phase Winco generator available in 540 or 1000 rpm models. While larger you can still use the same tractorif you don't overload it. This would allow you to meet your single phase loads you mention and still have three phase available for wood shop motors. Lots of good deals on used wood working equipment that is three phase since most hobby shops don't have it available. Winco has a 40 or 45kw three phase model around $4000.
