CNC Dan
Veteran Member
Well, lets eliminate the wire runs and sizes. Welder sets next to breaker box, plug is wired with 8ga wire. Now, is there any benefit of using a 30amp breaker over a 20amp, and does having 30amp's availalble, is it possible to pull more amps at the mig gun than it would if it was on a 20 or 25amp breaker. Or is the welder made so it cant pull more than a specific amount of amps, reguardless of breaker size, and using a bigger breaker just fooling everybody into thinking the machine will preform better.
Let me add, if its possible to pull more amps with a bigger breaker, will this effect duty cycle?
It won't effect how much the welder draws. Same settings on the machine, same current draw.
But.... You can use higher settings without tripping the circuit breaker.
If you arn't tripping a 20 amp circuit, then using a 30 amp circuit won't gain you anything.
