110VAC from 220VAC How to?
   / 110VAC from 220VAC How to? #91
A properly sized and installed transformer will work, I suggested that in one of my first posts. However, it will also cost a good bit, and I'd put my money into a generator before I'd go with a transformer.
   / 110VAC from 220VAC How to? #92
How about this one for $102
Amazon.com: VCT SIM-3000 Voltage Transformer AC 110V / 220V / 240V Step Up / Step Down Voltage Converter 3000 Watts for Worldwide Use CE Certified: Electronics
3000 Watt Maximum Capacity, heavy-duty continuous use transformer Converts 110/120 V to 220/240 V OR converts single phase 220/240 V to 110/120 V (switch is on back of unit) Compatible with 50Hz/60Hz. On/Off switch with indicator lamp 4 outlets on front of unit (outlets accept 3 or 2 prong US plugs and 2 prong Euro/Asian plugs One Universal outlet can accept 2or 3 pin plugs from UK,Australia,New Zealand,Asia or Europe. Insulated power cord is hard wired with a grounded European Shucko plug also good for Asian outlets Comes with 2 prong US adapter to enable non-grounded use in the USA, Canada and Mexico Grounded 3 prong US adapter also available - See Item No. VP 13 under Plug Adapters (grounded 3 prong US adapter also available - Item No. VP 13) Easy to carry with attached handle, heavy-duty metal casing Fuse Protected
James K0UA
2020 DRAGON ESP...
MERCURY VERADO ENGINES (A55758)
MERCURY VERADO...
HOBBS 48FT FLOAT (A55745)
HOBBS 48FT FLOAT...
Tafe 45DI (A53317)
Tafe 45DI (A53317)
2001 Diamond 20' Fuel Trailer, VIN: 5FWFS18241R000024, Tandem Axle, Asset# 27 (A59076)
2001 Diamond 20'...
2023 Kubota U55-5R1 Mini Excavator (A56435)
2023 Kubota...
