12" backhoe bucket with pics
   / 12" backhoe bucket with pics #12
Great looking bucket. Is there anyway that you could dimension and post the measurements for yor side plates? Thanks...
SORRY I AM NOT A DRAFTSMAN
I think I am in need of a 1 1/4 reamer to clean up the holes, also rear pin must have a slight bend, I will hold off finishing it till i get my kubota pins
   / 12" backhoe bucket with pics #15
decided to weld it up without kubota pins, after an hour of sanding the pins with drywall sanding screen and 400 grit paper, ripped a 1x6 and clamped as a jig. made small even stitch welds as to not bind the pins, i would weld one side and pins would lock up, then weld opposite side to regain movement, also decided to add a band around the back to the bottom cutting edge 1/4 x 1 1/2, weld the upper half heat at the bend with a torch bend over and use a lump hammer to fit tight, weld, repeat. marked the bucket with an s. in the end pins move fine, primmed painted. just need teeth to come in
   / 12" backhoe bucket with pics #19
Looks very good!!! How many $$$ in it?
LOT: (50) 14 Oz. Tubes of Star Fire Multi-Purpose EP 2 Grease (A59076)
LOT: (50) 14 Oz...
FRONT WHEEL SPACERS (A52708)
FRONT WHEEL...
2007 Kenworth Tandem Axle Road Tractor (A47477)
2007 Kenworth...
(INOP) RHINO 1310 ROTARY CUTTER (A52708)
(INOP) RHINO 1310...
Tandem Axle Rear Trailer Frame (A55851)
Tandem Axle Rear...
Truck Metal Cargo Storage Box (A55788)
Truck Metal Cargo...
