1260 ENGINE HEATER
/ 1260 ENGINE HEATER #1
BLK6RL
Brighton,Co
Has anyone installed an inline lower radiator hose engine heater? I have a 1260 with the 1 1-8th inch lwr hose, and was in hopes of not spending the $1oo+ on the agco block version. Also is there an aftermarket freeze plug style out there? Thx
/ 1260 ENGINE HEATER #2
Zerostart makes a block heater for your tractor. You might check out their web site to find a retailer. I am sure it would be less expensive than your dealer.
Here is their e-mail if it helps. Take off the ">" at the end. I couldn't get it to work any other way.
sales@phillipsandtemro.com>
/ 1260 ENGINE HEATER #3
NAPA can order the lower radiator hose heater for you, if there's one that fits your hose. I think they're made by Kat's. 1 1/4 or 1 1/2 inch sizes are pretty commonly available. I ordered one for my 1010 but found there was not enough space under the hood to install it properly. The heating element housing must be turned straight down to keep it immersed in the coolant at all times. Not enough clearance between the hose and the engine in my case to allow that. But it looked like a good unit to me.
Don't know how old your 1260 is, but I'd be willing to bet MF can supply you with the correct freeze plug block heater. And I've read on the internet how to install them. Doesn't look like a lot of trouble if you can reach the freeze plug that it will be replacing. I'm sure the dealer can do the work, but you might also find your local auto mechanic can do it easily enough if you can get the part.
Didn't note where you live, but a heavier battery is always a good idea.
Some people just put a 60 watt trouble light under the tractor, connect a timer to it, and lay a blanket over the hood to trap the heat from it. You'd need to keep the flammable stuff away from it to be safe.
