130 fuel delivery problem
   / 130 fuel delivery problem #1
msjanket
Will diesel fuel flow by gravity from the tank through the glass bowl, down through the fuel pump, through the fuel filter and then into the injector pump ? Or, does the pump have to be activated and pumping actively if this is to happen?When I take the line from fuel filter into injector pump OFF, I am getting no fuel delivery out the end of the unscrewed fitting. Is this an obvious sign of blockage? Or, does the fuel pump have to be working for fuel to come out the entrance fitting to the CAV pump?
thank you
Zero Turn Mower (A55853)
Zero Turn Mower...
2004 FREIGHTLINER CL120 TANDEM AXLE DAY CAB (A57880)
2004 FREIGHTLINER...
Hose Reel (A55758)
Hose Reel (A55758)
2008 Featherlite Portable Office Command Center T/A Trailer with Wacker Neuson G50 Towable Genera... (A56858)
2008 Featherlite...
2019 Ford F550 Chassis (A55973)
2019 Ford F550...
TAYLOR WAY 962 48" HYD TILLER (A57192)
TAYLOR WAY 962 48"...
