G,Day johnking.
First thing is to check fuel supply , turn the fuel tap of,remove the fuel line going to the carburetor turn the fuel tap on with a bucket to catch the fuel LET IT RUN FOR AT LEAST TWO MINUTES there should be a good healthy flow all the time if not turn the fuel tap of and remove the fuel line from the FUEL TAP CAREFULLY and turn the fuel on again you should get a good healthy flow ALL THE TIME it should not slow down, if this is no good siphon the fuel out of the tank and remove the complete fuel tap from the tank and get a piece of wire and start cleaning all the holes in there ,blow it out with LOW AIR PRESSURE ,make sure it is not blocked and when you are happy reassemble that is the fuel system proven TO THE CARBURETOR .
The next step is proving the ignition system , first MAKE SURE THE BATTERY IS CONNECTED THE RIGHT WAY ROUND POSITIVE TO EARTH then with the ignition turned on check with your test light that you are getting 12 volts to the SW or NEGATIVE ON THE COIL if this is good remove the low tension wire the thin one on the other side of the coil,marked either POSITIVE or E FOR EARTH then remove the high tension wire from the DISTRIBUTOR the thick wire in the centre of the cap and hold the end near the coil body say 1/8 th inch away, then get a piece of thin wire and connect it to the terminal that did go to the distributor and with the other end scratch it on the coil body if the coil is good you will get a good bright spark one which you can HEAR, if this is all good go to the distributor .
Remove the cap and first check the carbon pickup brush in the centre of the cap push it in lightly and it should have spring pressure on it pushing it back out the carbon rod should be minimum 1/8 th long if not replace it.
Next thing remove the rotor button and give it a good clean.
Next check the contact points ,I dont know how savvy you are with things mechanical so you may need help with the points, remove the points and either replace the points AND the condenser ,they dont cost much, pay special attention to the INSULATING WASHERS on the spring end of the points when reassembling ,remembering that the spring and everything attached to it MUST BE INSULATED that is it should not go to earth to test after reassembling the points turn the engine by hand until the points are OPEN that is you can see an air gap between the contacts on the points,then with your test light connect it to the SUPPLY side of the battery normally wired positive to earth then with the test light end touch the terminal on the distributor that the coil wire would be on ,IT SHOULD NOT LIGHT UP WITH THE POINTS OPEN if it does there is a problem with the insulation going through the distributor body,fix the problem and test again ,when this is all good reconnect the wire from the coil to the distributor the thin one then refit the high tension wire the thick one to the cap .
Note : If for example the battery was in the wrong way the low tension voltage would be going through the coil the wrong way i.e. the supply would be going through the secondary windings first instead of the primary windings this will result in a poor spark and consuequently cause what looks like and most often is flooding ,to much fuel.
Do all of these things and keep us posted .
The most common fault with ignition systems on tractors are earthing problems .
P.S. I like The Kids cake is it pecan pie???
Happy Days .
Hutch.
