135 Weight Bracket and weights...now on...
   / 135 Weight Bracket and weights...now on... #1
BobG_in_VA
Central VA, USA
Mahindra 6000 MWFD, 2 1950's Farmalls, 1974 Farmall 140, 1967 Mf 135Delux
Got the bracket, had to burn some holes in it so the Mahindra weights would bolt on..I have a 7ft extreme duty box blade on the back that weighs around 6-700 lbs...now holds the ground good. Try to upload some pics. BobG in VA
   / 135 Weight Bracket and weights...now on... #2
I remember you saying 2"x5/8" bolt but what threading?
Scott...not really sure...I just got them as TSC out of the bin...they fit..its not a fine thread...sorry..You can look up under your 135 and see the threading..it may help you.BobG in VA
   / 135 Weight Bracket and weights...now on... #4
It would be 5/8 - 11 which is a standard coarse thread.
   / 135 Weight Bracket and weights...now on... #5
Scott,the manual says 5/8" X 2" NC, Hex
NC is coarse thread or 11 thread per inch. NF is Fine thread = 20 thread per inch. You could use TSC's common bolts sold by the pound. Grab some 5/8 flat washers too.
You will have plenty of "purchase" with the 2" bolt. I used one flat washer (against engine frame) and one lock washer (against the bolt head). Not ever intending to have it come loose. BobG in VA
TANK MANIFOLD (A55745)
Drago Olimac 6R Corn Head (A59814)
Drago Olimac 6R...
MURRAY PUSH MOWER (A58214)
MURRAY PUSH MOWER...
1995 NEWTON CROUCH PULL SPREADER (A57192)
1995 NEWTON CROUCH...
2021 JOHN DEERE 6145R TRACTOR (A59823)
2021 JOHN DEERE...
1979 Ford F-100 Ranger Pickup Truck (A59230)
1979 Ford F-100...
