1401 PTO issue URGENT!! Need to fix!!!
   / 1401 PTO issue URGENT!! Need to fix!!! #21
The PTO is an assembly. Take the darn thing out. It should take way less than an hour to pull it apart. Then you can see if its a gear in the assembly or on the mainshaft of the tractor. If the Assembly you may be able to buy a used unit from Hoye and just drop itin and go.
   / 1401 PTO issue URGENT!! Need to fix!!! #22
Johndeere3720:
Thanks for the help with my problem. I am going to assume that you read my post to 'clemsonfor' above.
I looked at your tear-down pictures along with your copy of the manual. I do have the manuals that go with the tractor.
My understanding from looking at what you posted is that the drive to the rear tractor wheels and the PTO are directly related yes? That is to say some components are shared between the functions of running the tractor drive-train and running the PTO.
Do you have to remove the tire to get at the PTO or was that to facilitate your access to the seal you mentioned?
I was intending to call HOYE today and talk with them about this issue to see what feedback I'd get. Any other source of technical help you know about?
Thanks again for the assist.
Jon
He removed the tire to get at his hydro screen easier. The PTO removes from the back. GET down there and look you will see i thing l4 bolts that are like 3/4" take them out and pull it out.
Thanks Clemsfor:
I'll pull it tomorrow morning.
I'll upload pix as I go.
Jon
UNUSED FUTRE FL-ESC220 ELECTRIC STONE CRUSHER (A52706)
UNUSED FUTRE...
2017 Kubota M7-151 Premium MFWD Tractor (A56438)
2017 Kubota M7-151...
2020 CATERPILLAR 299D3 SKID STEER (A60429)
2020 CATERPILLAR...
2019 CATERPILLAR D6 HIGH TRACK CRAWLER DOZER (A60429)
2019 CATERPILLAR...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
John Deere 1025R (A53317)
John Deere 1025R...
