16' x 24' Mini-barn build
   / 16' x 24' Mini-barn build #21
I'll follow ye thread, IH. I'm always interested in this slab vs. pier debate. I'm needing a new bigger barn, and not wanting to go slab either due to cost.QUOTE]
There is no cheaper way to build a strong building then pole barn construction. Setting the poles in the ground and installing purlins for the walls is a time proven, cost effective and easy to do method that is very strong. Installing trusses or putting a post in the middle and installing beam the length of the building so you can go with rafters is the same for anytime of building, so that's a push. Not having to put in a foundation, or grading the land, means huge cost savings in time and materials. Adding gravel at a later date is also the most affordable flooring to have, but it does mean dealing with rocks that work their way up and not having a perfectly smooth surface to work on. For just storage, it's great.
The reason I suggested that the OP go with concrete is that he was creating a fairly complicated foundation for his barn that would be less complicated with a much better surface if he just went with concrete.
Eddie
   / 16' x 24' Mini-barn build #22
You nailed it for me, Eddie! Site is not level, need big strong about 36'x36', and ain't selling nary hind leg to build the thing! 6x6s 4' or so in me red clay should do it I reckon. Figure I can make the low roofed side really high, then later do the leveling and add gravel. Got to get me mess under a roof!
   / 16' x 24' Mini-barn build #24
Nice! How much did the trusses set you back? Depending on how much family stuff we have going on for Easter I may get to digging the footings and grading... I'll be using crushed concrete for fill/base in and around the barn but I'm having trouble finding it. Seems its gotten so popular as a road base the quarries are sending the finished product out faster then they're getting raw demo concrete in these days.
I will check when I get home but I believe 100 each
And I will post pic too
2012 GROVE TMS900E TRUCK CRANE (A58214)
2012 GROVE TMS900E...
Takeuchi TB016 (A53317)
Takeuchi TB016...
CAT D8 (A58214)
CAT D8 (A58214)
CONCORD CRE96018B CONVEYOR BELT (A52706)
CONCORD CRE96018B...
EZ-GO Electric Golf Cart (A60462)
EZ-GO Electric...
Caterpillar D6K LGP (A53317)
Caterpillar D6K...
