1610D throttle and white smoke
   / 1610D throttle and white smoke
Roger, thanks for hanging in there and offering some further thoughts. No, my machine doesn't have an electrical shut off. I am also pretty used to the "yanmar-hammer" from my two cylinder 1300D, which I also feared had some major problem when I first got it and came to realize was just fine. In the case of my new machine, the 1610D, it may be ok but I think something is not quite right. Without a load it is fine but when going up a hill at less than substantial revs it does ping, much like a car. Your notion that the fuel might be bad is interesting. I put in new diesel fuel, having drained the old and installed a new fuel filter, when I first got it--this fuel being straight from my local gas station. There's only a bit in there so I'll soon swap it out for new and see if that makes a difference. I suspect it is something else, however, such as either bad injector timing or fuel pump maladjustment. Think I'll just haul it in to a local shop and see what they say. Thanks again for your help. Eric
2001 DITCH WITCH 8020 RIDE ON TRENCHER (A51242)
2001 DITCH WITCH...
Bad Boy 31HP Pro Series Mower (A50514)
Bad Boy 31HP Pro...
2022 LEGUAN 190 SPIDER LIFT (A51242)
2022 LEGUAN 190...
TRAILER AXLE (A51244)
(9) SHANK ALL PURPOSE PLOW (A51243)
(9) SHANK ALL...
2019 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2019 FORD F-150 XL...
