16LA Removal w/o Kickstand
   / 16LA Removal w/o Kickstand #11
Mark is it not possible to R&R the kickstand mount on the loader arms while it is still attached to your tractor for support? I'm not recommending crawling under the loader unless you have them blocked up but it seems to me that might be easier done while still attached to your tractor for stability.
   / 16LA Removal w/o Kickstand #12
Mark, when you giggled the joystick, you allowed the curl cylinders to also relax. That's why your pallet forks didn't hold the loader arms up at least until you could get the tractor backed away. Frankly, I uninstall and reinstall my loader on a regular basis with the tractor running and the joystick just centered. If there's no heavy load on the cylinders, the qick-connects will work easily.
Yes, but I don't know when I can get a guy with a welder in here. Just thought I'd try to delay spending the $ until later.
Mark
</font><font color="blue" class="small">( I uninstall and reinstall my loader on a regular basis with the tractor running and the joystick just centered.)</font>
I never tried this - always followed the instructions in the manual (plus your "classic" post on loader removal /forums/images/graemlins/grin.gif) I'll try it AFTER (apparently) I get the kickstand fixed.
Mark
   / 16LA Removal w/o Kickstand #15
</font><font color="blue" class="small">( ...always followed the instructions in the manual ... )</font>
Yeah, me too. Then one day I forgot to shut off the engine and I found the whole process went just fine. The only time I ever had any difficulty whatsoever was when I took the loader off at 50°F and then tried to install it when it was 95°F out. /forums/images/graemlins/tongue.gif I had to loosen the connections in the lines. The pressure was so great the hoses were sticking out straight from the loader. I bet the pressure inside must have been nearly 4000 psi. /forums/images/graemlins/shocked.gif
BTW: One day I forgot to fold my kickstand, but I realized it before any damage was done. Another day, I had my front bumper folded down and worked half the day with it that way. /forums/images/graemlins/blush.gif I understand how these things happen. /forums/images/graemlins/crazy.gif
   / 16LA Removal w/o Kickstand #16
<font color="blue"> BTW: I had my front bumper folded down and worked half the day with it that way. I understand how these things happen. </font>
Whew! I'm glad you fessed up to that one Jim cause I thought that I was the only one that ever did that. /forums/images/graemlins/tongue.gif I feel much better now.....
   / 16LA Removal w/o Kickstand #17
<font color="blue">I took the loader off at 50°F </font> ..... Jim, be careful working in that cold weather !!!! /forums/images/graemlins/grin.gif
   / 16LA Removal w/o Kickstand #18
</font><font color="blue" class="small">( Jim, be careful working in that cold weather !!!! )</font>
Yesterday afternoon I was driving in 70° weather and noticed a sign on the side of the road that said "Watch for ice on bridge." I guess TxDOT puts those signs up when temperatures are consistently below 80° here. /forums/images/graemlins/crazy.gif
Who says Texans don't have a sense of humor? /forums/images/graemlins/laugh.gif
CATERPILLAR 259D3 SKID STEER (A50458)
CATERPILLAR 259D3...
2001 Nissan Frontier Crew Cab Pickup Truck (A51692)
2001 Nissan...
2013 PETERBILT 386 TANDEM AXLE SLEEPER TRUCK (A52576)
2013 PETERBILT 386...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52748)
80in HD Tooth...
Texas Post Driver Series 500 Heavy-duty Hydraulic Post Driver (A52748)
Texas Post Driver...
