DieselPower
Elite Member
- Joined
- Sep 30, 2006
- Messages
- 2,756
- Location
- Fairfield, PA
- Tractor
- JD 3020, JD 4230, JD 7410, JD 2440, MF 750, NH LS170
I purchased this Savage shortly after they introduced the 17 HMR. With the addition of the Swarovski scope (I know I'm nuts, a $1,200 scope on a $200 rifle) and a little trigger shimming to lighten the pull (pre acutriger) all I can say is critters beware!!! I have pushed close to 9,000 rounds through this gun, killed hundreds of ground squirrels, just over 100 ground hogs in MD and PA, more birds than I can remember and even took a white tail doe a couple of years ago with it (don't tell the game warden though
The only two downsides are both due to the light bullet. Wind drift can be horrible if your not familiar with firing this cartridge. If you plan on serious hunting with it I highly suggest doing a bit of target shooting in the wind. The other problem is range. If your staying under 200 yards you should be fine, over that it has slowed so much you have lost most of your energy.
One additional thing I have found with 17 grain V-Max bullets is that it's darn near impossible to ricochet them. I have tried firing at very low angles into the ground, at tree branch's set up in front of a target and even tried bouncing them off water in a pond. They are so thin skinned they just seem to disintegrate on contact with anything.
Don't plan on fur hunting small game with this round. I have completly blown ground squirrels and rabbits in half with it.
My opinion, buy it you won't regret it. It's a superb cartridge when used on the proper game.
