1735m - bending sway arms - why?
   / 1735m - bending sway arms - why?
Wouldn't it be easier to cut an inch or 2 off the exiting insert?
it would be closer to 4 inches but yes.... that is a possibility
   / 1735m - bending sway arms - why? #12
From the pics it looks like you have several inches of adjustment left to make them shorter. After straightening them, just remove the pins when hooking up, allowing the stabilizer/insert to move in/out as needed. After hookup to the attachment is complete, reinstall the pin in whichever hole lines up for the best fit.
   / 1735m - bending sway arms - why? #13
Also said:
The OP used the term "brush hog." Nothing wrong with that and many users say it. I suspect more people use that term out in the country side than "rotary cutter." Rotary cutter is a bit more universal among manufacturers and in the literature. Bush Hog is as you say a brand name.
   / 1735m - bending sway arms - why? #14
Super easy to straighten. Hard flat surface and a 3 lb hammer.
Afterward keep them snug but not tight. Make sure 3 pt with implement can raise and lower without binding.
BFH 1000 BALANCE FORCE HARMONICS TIRE BALANCER (A54757)
BFH 1000 BALANCE...
2020 Freightliner M2 106 Elgin Whirlwind Series MV Street Sweeper Truck (A55852)
2020 Freightliner...
70pc. 12ft. x 3ft. White Metal Roof/ Wall Panels (A53424)
70pc. 12ft. x 3ft...
2014 Volkswagen Passat TDI SE Sedan (A55853)
2014 Volkswagen...
UNUSED FUTURE 20' WROUGHT IRON BI-PARTING GATE (A57193)
UNUSED FUTURE 20'...
2019 HINO 268 26FT BOX TRUCK (A53426)
2019 HINO 268 26FT...
