1845 owners, check your VV pump bolts
   / 1845 owners, check your VV pump bolts
There are no lock washers. Regarding alignment, that's not really an issue ether because the mounting plate is precision machined (I'm assuming it was machined correctly of course). I now think the bolts probably began loose and I neglected to check them as planned. I will watch them closely for a while.
One interesting side point. The engine connects to the pumps via a plastic gear. The gear is mounted on the pumps and fits inside a plastic ring mounted to the engine. I guess plastics really are the future.
   / 1845 owners, check your VV pump bolts #12
So there is no Lovejoy coupling on the 1845?
Correct. This is the reason I can't really reinforce the mounting. Basically, without a lovejoy, the motor and pump assembly must vibrate together as one unit.
2019 ALLMAND NIGHT-LIFE V SERIES LIGHT PLANT (A52706)
2019 ALLMAND...
2001 CATERPILLAR 420D BACKHOE (A52707)
2001 CATERPILLAR...
WEB PUMP ON CART (A55745)
WEB PUMP ON CART...
500 BBL WHEELED FRAC TANK (A55745)
500 BBL WHEELED...
2022 Club Car Tempo Cart (A55853)
2022 Club Car...
2020 FREIGHTLINER M2 SINGLE AXLE BOX TRUCK (A56129)
2020 FREIGHTLINER...
