190c riding mower runs like it is on one cylinder....
   / 190c riding mower runs like it is on one cylinder....
I watched the video and it's for sure choking to death on too much fuel.. If I was doing this, I would get it running like in the video, and then disconnect the fuel line.. (Or pinch it closed good). Or turn the gas off if it has a valve..
The point would be to see if the engine cleared out and ran smooth for a few moments before it runs out of gas.. If it does then we could maybe know the carb has a jet or something that has fallen out, or something causing it to offer too much fuel.. Float might have a hole or needle leaking..
Last quick guess. Don't rule out the flywheel key if nothing else ever helps or works.. Only a couple of times I've seem this where it shears and slows down the timing so late that the engine barely runs and will mimic being flooded..
I actually thought of flywheel key, and forgot I had taken pictures
I had a question.
where on the flywheel is the key and is there only one?
I took pics...this is just an empty slot...not sure if the key was in there and fell out?
this is another spot on the flywheel that I thought might be the timing key...
and then there is this hole...
I'm assuming one of these is the flyweel key?
I had the same mower a few years back and had a fuel delivery problem. The hose form the fuel tank would get pinched and prevent the motor from getting the right amount of fuel. Basically the thing would run but had no power. Finally figured it out and found where the hose was being pinched and it worked fine. Might follow that fuel line and see if there are any issues.
I would be really surprised if this was a fuel delivery problem...but what do I know...
but when I pull the fuel line from the fuel pump, fuel just comes gushing out.
I did trace the line back and it doesnt look pinched and there are no wet spots indicating a leak that I can see...
I was going to replace it anyways, just because it is a ten year old mower.
   / 190c riding mower runs like it is on one cylinder.... #23
I thought the flywheel key would be the one that alignes the flywheel to the crank shaft, and a key (half moon or square bar) that slides in when the flywheel is slid onto the shaft. Sometimes, in some engines, a backfire will cause the key to shear and not align the two parts, thus the timing gets cockeyed.
   / 190c riding mower runs like it is on one cylinder.... #24
Yes Matt, it's what Beenthere is saying... The flywheel key will be under the big nut holding the flywheel onto the crankshaft..
The flywheel has to be mounted in the correct position relative to the crankshaft.. The key is a small square metal piece that half of it fits in a groove cut into the crankshaft, and the other half fits into a slot cut into the flywheel center hole,, thus holding the flywheel in the correct position, then the big nut is tightened that holds it all together.
The process to check it is ;; First the big nut is removed, then a puller is used to remove the flywheel from the engine.. From that point the alignment key will be found and can be observed to see if it's sheared away (broken).
On some engines you can see the square groove in the flywheel and the square groove in the crankshaft as soon as you remove the big nut and any washers. If so,, you can tell if the key is broken right then..
If you can see theses grooves,,, and if they are lined up together, the key is ok,,, if the grooves are not lined up together,,, then the key is broken...
   / 190c riding mower runs like it is on one cylinder.... #25
If the "Flywheel" key was broken the engine would not start. The engine will reportedly start and run on one cylinder. Look at the flywheel in the photos that were posted. The flywheel to me has the appearance of an engine that has been exposed to the weather from the rust and pitting.
yes it will run and start...just very poorly
also, since I've owned the mower it has been kept in a garage. Most of it's life has been spent in central florida.
I know humidity is high there, so maybe this is the reason for the rust.
but it has never seen rain, or snow, or salt...and has always been in a garage.
now, that said, would that rust on the flywheel affect the timing somehow? The coil's look like they time off the flywheel...
but again, when I test spark, the spark is healthy and looks normal.
thx beenthere and bill, I will check the key today and see what it looks like...seems easy enough...
   / 190c riding mower runs like it is on one cylinder.... #28
Matt,, I would try what I first mentioned first about starting it up and then cut off the fuel supply to see if it ever clears out and runs normally for even a moment before it runs out of gas...
This will tell us something. If it does run ok for the last second or two,,, it would seem like a overly rich situation pointing back to the carb...
It it continues to barely run even down to the last drop of fuel available ,,,, then that's when I would go ahead and check the key....
Yes, the engine will run or will not run with a sheared key... It depends on how much the flywheel slips on the crank when the key breaks... Too much and it will not run,,, or every now and then blow a fireball out of the muffler or the carb with the classic sonic boom I'm sure some readers here have heard before..
BUT,, if the key breaks and the flywheel slips only a little (like 1/8 turn) or less,,,, it will run the way your engine was in that video.... I've seen this twice in my life, and both were Briggs engines with the square cut flywheel key.. (And I think that is what yours uses)
   / 190c riding mower runs like it is on one cylinder.... #29
The coils are actuated by magnets built into the flywheel. You can find the magnets easily with a screw driver. Just rotate the flywheel and slide the screw driver along the flywheel in the area where the coils interface with the flywheel. Use a medium to fine grade sand paper to clean the magnet area of rust. Also place a light coat of oil on the area after sanding and wipe it off. The air gap between the coils is usually 10-12 thousand. A good way to adjust the coil air gap is to loosen the coil and insert the applicable filler gauge and let the magnet pull the coil in and hold it while you tighten the holding screws on the coil. The use of a brass filler gauge makes the extraction of the filler gauge easy after adjusting the coil. A metal one can be used, just harder to get out.
https://vimeo.com/105262199
made a video.
took some pliers and restricted fuel to carb while it was running...after about 10 seconds or so, it picked up and ran better.
did this multiple times, and even after letting go with the pliers, it would run pretty good for a bit...
so I guess this means I'm pulling the carb apart again doesnt it...
2007 Volvo VNL Truck Tractor (A53473)
2007 Volvo VNL...
2005 MGL. ENGINEERING 7436 CONVEYOR (A53426)
2005 MGL...
2008 CATERPILLAR 304C CR EXCAVATOR (A51406)
2008 CATERPILLAR...
(2) METAL SPOOLS W/ SOME DURALINE 4" PVC PIPE (A51248)
(2) METAL SPOOLS...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
Alliance Flotation Tire (A50123)
Alliance Flotation...
