beenthere
Super Star Member
- Joined
- Aug 16, 2001
- Messages
- 18,553
- Location
- Southern Wisconsin, USA
- Tractor
- JD_4x2_Gator, JD_4300, JD_425, JD_455 AWS, added JD_455, JD_110, JD_X485(sold)
Seems like it was a good test. :thumbsup:
When you took the carb apart you said it looked clean so you only replaced some of the stuff.
Did some of the stuff include the needle valves and seats?
Jim Inman on TBN always advised that the tips of the needle valves were rubber and that they get messed up by the gas we get today even if you use an additive.
We have a L120 with over 1000 hours on it. A couple years ago the wife complained that it was running ruff. The paper clip clean out of the gas cap breather hole
worked for a while but would repeat the missing after a half acre or so. I took the cap apart. There is a splash plate under the rubber that has a shaft that rides up and down in the center tube that has the vent hole in top. It seemed to be binding a bit probably from the plastic pin scarring the tube. Rather than buying a new gas cap, I carefully drilled out the shaft hole another 1/32" on my drill press. That corrected the vent sticking problem.
The missing reappeared, always seemed to be on the side the oil filter is on ( the left side, when sitting on the seat).
I was about to get a carb kit and rebuild it, but had read some threads by Western, on TBN, and others about how great Seafoam was at cleaning carbs.
I had never used it before. My old days of using gumout on Holley 4 barrels, as a kid, made me skeptical.
The Seafoam still comes in a metal can so I was a little anxious about using it in a modern carb with plastic and rubber parts... but.
I ran 1 full tank of fuel with 2 oz. per gallon of Seafoam in it. It started running better as the fuel was consumed and was running like a new engine by the time the tank was almost empty.
It has run fine for 2 summers now, about 8 hours per week, with no re-treatment. We do use Stabil in every batch of gas now, but used it most of the time before, and always in the gas that sits in anything over winter.
I have no interest in either of these products. Just something to try if you haven't already, and you know you put your carb back together right the first time, along with putting the linkages back on properly for the choke and governor..
I stopped by my old shop today and I mentioned this situation to them. They are much more into lawn and garden today and they have dealt with a lot of the Briggs twins.
They agreed that yes, they had seen issues like I described on the Briggs twins before. They said because of shop labor rates they had started replacing the carb with a new one rather than the labor cost of trying to fix. (I think they had some prior boomerangs and that caused that decision)
They mentioned plastic parts and o-ring issues around the main jet area at the bottom of the float bowl..
I liked hearing that maybe this had been seen before, but I didn't like hearing about the hard to fix plastic parts carb..
