1953 John Deere A
   / 1953 John Deere A #1
Bquick
Shelton Ne
John Deere Model A
I'm having trouble with hydraulic fluid leaking past the PTO shaft into the transmission. I have replaced shaft as well as the rubber seals and spring. Anybody have this trouble and find a better solution? Sorry it is a 1952
   / 1953 John Deere A #2
Did you install the seal backwards? I have seen a seal installed backwards on a Farmall cub on the rear main seal causing it to leak oil into the clutch housing.
   / 1953 John Deere A
Mike, I don't think I did all it is a two rubber o rings between two plates with tension on them by a spring
2015 Ford Explorer AWD SUV (A55853)
2015 Ford Explorer...
EZ-GO Electric Utility Cart (A55851)
EZ-GO Electric...
2014 Chevrolet Impala Limited Sedan (A55853)
2014 Chevrolet...
UNUSED Under Mount Stainless Steel Sink & Faucet (A53117)
UNUSED Under Mount...
23013 (A55787)
23013 (A55787)
