1953 John Deere A
/ 1953 John Deere A #1
Bquick
Shelton Ne
John Deere Model A
I'm having trouble with hydraulic fluid leaking past the PTO shaft into the transmission. I have replaced shaft as well as the rubber seals and spring. Anybody have this trouble and find a better solution? Sorry it is a 1952
/ 1953 John Deere A #2
Did you install the seal backwards? I have seen a seal installed backwards on a Farmall cub on the rear main seal causing it to leak oil into the clutch housing.
/ 1953 John Deere A
Mike, I don't think I did all it is a two rubber o rings between two plates with tension on them by a spring
2007 Rhodes AS3573 Trailer, VIN # 1A9AD35307P432073 (A64556)
2007 Rhodes AS3573...
2021 SANY SY26U EXCAVATOR (A63276)
2021 SANY SY26U...
2017 Ford Explorer SUV (A64557)
2017 Ford Explorer...
2015 Peterbilt 348 T/A 24ft Chemical Transport Flatbed Truck (A64194)
2015 Peterbilt 348...
2014 GULF STREAM TRAILMASTER (A65643)
2014 GULF STREAM...
Wooden chair (A64557)
