1953 Super "C" Snowcat
   / 1953 Super "C" Snowcat #11
Many years ago, tracks like that were used around here quite a bit, on several different brands of tractors. Mostly to use on soft ground, like in "muck" fields...
SR
   / 1953 Super "C" Snowcat #12
Very nice! Hope you get some snow to put it to work!
   / 1953 Super "C" Snowcat #13
Did you see how i painted my hay trailer in the background? Wouldn't have painted it any other way.
Whoever painted that trailer, is quite an artist. Love it..!!
   / 1953 Super "C" Snowcat #14
I'm very fond of the painted hay trailer and thank you for serving
   / 1953 Super "C" Snowcat #15
I've seen those tracks a lot lately. There's a Farmall 140 on Craigslist with a set for sale right now
Well i'm still waiting for some decent amount of snow to fall. So far we've only had 3 inches at one time but if the wind doesn't blow at gale force levels we may get some good accumulation so i can really test this toy out. I Think anything over two foot would try it's metal good. Can't wait. I Did notice the fuel has a hard time igniting in the cold temps so i'm going to try one of those magnetic engine oil pan heaters to radiate some heat upwards in the engine and i'm thinking of adding a ether spray line from the cab to the carb. intake tube to help it start a little easier. They have a brand of ether up here that has a tube attached to the nozzle and i was thinking of getting a three or four foot length of the small gas tube they use on weed eaters and run it down and thru a drilled rubber stopper in the side of the tube going to the carburetor so i can give it a squirt from inside the cab. I Have one of those plastic fire extinguisher wall mounts that i can clamp the can to inside the cab so that might help me a good bit to get started quicker.
2017 CATERPILLAR D6N LGP HIGH TRACK CRAWLER DOZER (A60429)
2017 CATERPILLAR...
2018 CATERPILLAR D6N LGP HIGH TRACK CRAWLER DOZER (A60429)
2018 CATERPILLAR...
(2) POLY DRUMS (A52708)
(2) POLY DRUMS...
2020 FORD F-150 XL CREW CAB TRUCK (A59823)
2020 FORD F-150 XL...
2014 AMERITRAIL TUGGER TRAILER (A58214)
2014 AMERITRAIL...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
