1954 Jubilee
   / 1954 Jubilee #21
you will have fun doing the brakes onthe 30.. :) good learning experience.. assuming they are not simply out of adjustment.
soundguy
Or just glazed over.
I think he got a good deal on the 30. And as someone else mentioned, the attachments he's looking for can be found cheap with patience.
   / 1954 Jubilee
The CASE is pretty (just looked at it). It also comes with the following: trailer, lift, hoe, brush hog, 7 foot blade, tire chains. The brakes and clutch are fine. The carb leaks gas out the bottom (it's an upflow carb). The rear pto lever control is jerky and wonky. If I raise it half way, and then attempt to raise it all the way it actually lowers sometimes. The PTO itself is in fact custom to CASE so I need a slightly longer bar if I attach something to the pto. The narrow front end is not good in the mud and back home on the ranch I have a mud pit which needs to be scraped and graded. The other annoying thing about the case - the side pulley is always spinning. I'd have to remove it for safety and for the fact that it doesn't self brake when the clutched.
All in all the TO-30 seems more handy, the controls work smoothly, it doesn't leak anything... it doesn't come with anything though and it's not quite pretty. It also has more HP, is narrower, lower, more stable, better in mud.
I should buy them both, keep the TO-30 and case's implements, and sell the CASE.
   / 1954 Jubilee #23
or fix it up for a parade OR for a 2nd helper tractor!
   / 1954 Jubilee #24
Just made me shudder reading about the belt pulley spinning all the time......... :(
2018 CATERPILLAR 259D SKID STEER (A51246)
2018 CATERPILLAR...
STORAGE FEES (A52576)
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A52576)
2018 FREIGHTLINER...
2021 MACK GRANITE TRI AXLE DUMP TRUCK (A52576)
2021 MACK GRANITE...
2014 Chevrolet Equinox SUV (A50324)
2014 Chevrolet...
