The main thing I can think of if you aren't familiar with wet sleeved engines, is to be sure to clean the oring grooves thoroughly and also the upper land and bore in the block where the sleeve fits. When you get the new sleeves, dry fit them in the block without the orings. They should slide all the way down easily. Clamp it in place with a couple of bolts and washers. Then measure how high the outer land of the sleeve is above the block. Should be .001" to .004" above the surface of the block. Sometimes you might need to juggle the sleeves from one hole to another to get a good fit. Once the liner height is correct, install the orings and lubricate them with liquid soap, not oil, and install the liners.
